603,371 active members*
4,487 visitors online*
Thread: G66 PROBLEM
    Dec 2004
    150
    G66 PROBLEM
    Hi Scott, hope you are well.
    I may have found another problem. When using G66 modal sub call, ncp doesnt seem to work on arc moves. Please plot mocked up program to see problem. What this is for is, we do some drilling thru an extended bush around a turned boss so if we move linear the bush could collide with the boss. So i came up with the idea of arc moving around the part and drilling with a sub.
    O1234
    G21
    G0Y74.5
    X0
    G66P7000
    G2X73.37Y12.94R74.5F1000.
    G3X71.49Y20.95R74.5F1000.
    G3X68.75Y28.71R74.5F1000.
    G3X65.16Y36.12R74.5F1000.
    G3X60.27Y43.79R74.5F1000.
    G3X54.49Y50.81R74.5F1000.
    G3X47.89Y57.07R74.5F1000.
    G3X40.58Y62.48R74.5F1000.
    G3X32.66Y66.96R74.5F1000.
    G3X24.26Y70.44R74.5F1000.
    G3X15.49Y72.87R74.5F1000.
    G3X6.49Y74.22R74.5F1000.
    G67
    M60
    M30
    O7000
    G0Z10.0
    G1Z-100.
    G0Z10.
    M99
    I have tried this on a fanuc 18 and it does work as expected.
    Keith.
    765
    Thanks Keith, I'll take a look at this.
    Scott
  1. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  2. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
  3. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
