588,548 active members*
5,678 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Tool changer problem Leadwell MCV-760 CR
    Oct 2011
    Question Tool changer problem Leadwell MCV-760 CR
    Hi
    Have a cnc- millingmachine, Leadwell MCV-760 CR with fanuc o-m control system.
    I have a problem with the tool changer/magazine, I can only use 14 out of 24places.
    When I try to call a tool higher than 14 I get an alarm code "1037 T.no not registered".
    If you need more info, just ask.
    Greateful for help!
    Jun 2008
    1511
    I don’t know exactly how it is going to be setup in your machine control but this is typically set on the PMC side of the control. There should be a tool table that you can set the tool and life of the tool there. If they are not set then you will get the alarm.
    Stevo
    Aug 2007
    58
    I have a leadwell VMC with Oi-MD control.
    This has the Leadwell ATC software.
    With this you can "unload tool" i.e leave certain pockets not available.
    I have a large oversize slit saw (T19) and either side there are empty pockets (T18 and T20) are not available and would give an error if I called them.
    On your MCV you might have to tell the software that tools 14 to 24 are loaded.
    Don't know if your O-M MCV control is the same, but might be worth a try?
    ATB
    Oct 2011
    Quote Originally Posted by derekBPcnc View Post
    ATB
    Hi and thanks for the answear!
    I agree with you, there should be a way to load and unload tools, the problem is that we dont know where to do it. We have spent some time going through the menus and we have found a tool library but there does not seem to be a way of loading/unloading tools there.
    Regards
    Feb 2015
    Question Re: Hello, I need floppy disk backup of this machine. tank you.
    Quote Originally Posted by Nilsson.ganda View Post
    Hi
    Greateful for help!
  1. VM1 Tool changer air problem.
    By rustyolddo in forum HURCO
    Last Post: 04-16-2013, 11:46 PM
  2. Tool Changer Problem
    By coop31 in forum Cincinnati CNC
    Last Post: 03-06-2013, 07:04 PM
  3. VMX 24 Tool Changer Problem
    By islandracing in forum HURCO
    Last Post: 01-28-2013, 12:59 PM
  4. Leadwell, Tool select problem...
    By jgabriel1983 in forum Controller & Computer Solutions
    Last Post: 10-30-2011, 06:11 AM
  5. tool changer problem
    By kling8 in forum Mori Seiki Mills
    Last Post: 02-25-2010, 02:54 PM
