586,190 active members*
4,086 visitors online*
Results 1 to 6 of 6
    Jun 2011
    36
    WRITE PROTACTED ERROR
    hi,
    I have a CNC Machine of FANUC MV-series 106A.
    when I try to give any input to position it says " Write Protected "
    can any one pls guide me to remove this error
    thanks
    nuzmeed
    Aug 2011
    2517
    usually there is a key in a lock on the panel to enable writing to the memory.
    turn it to the write-enable position.......
    Jun 2011
    36
    Quote Originally Posted by fordav11 View Post
    can you please describe in detail to follow the instruction .
    I will be glad for it .
    Jun 2011
    36
    the Edit LOCK key is in ON position
    Feb 2006
    1792
    make it OFF
    Jun 2011
    36
    hi, the problem is resolved. actually the connection of EDIT KEY Lock was loose from Inside. I have fixed it.
    thanks for the Support Guys
  1. Replies: 8
    Last Post: 04-30-2010, 11:54 AM
  2. Write Wizard Help!
    By ibuildstuff4u in forum Mach Wizards, Macros, & Addons
    Last Post: 08-12-2009, 06:25 AM
  3. how to write a subroutine
    By Harryman in forum G-Code Programing
    Last Post: 08-04-2008, 05:04 PM
  4. Ladder, can be write on pc?
    By Selimsalim in forum Parametric Programing
    Last Post: 07-28-2008, 08:58 PM
  5. write protected dwg
    By smudger in forum Autodesk
    Last Post: 09-05-2007, 08:26 PM
