588,525 active members*
7,802 visitors online*
    Oct 2011
    Machine Recommendations
    Hello,
    I am a new member interested in bench top CNC machining. My goal is to produce and market small parts of my own design, mostly fabricated out of aluminum. The parts require several milling actions along with boring and threading lathe work.
    I currently make the parts on my vintage 6” Atlas lathe but the repeatability of CNC is intriguing.
    Because I am new to the CNC aspect, I would like equipment with good customer support. While the Shearline and Taig equipment is big enough for my needs I’m looking for something a bit more robust. That said I don’t have a fortune to spend (Tormach, MicroKentics type budget).
    I’m very interested to hear recommendations.
    Thank you and best regards,
    Feb 2009
    152
    If you need to do both CNC milling and lathe work in the size you describe, the machine in this link may be one to consider.
    http://www.cnczone.com/forums/shopma..._you_tube.html
  1. CNC machine recommendations?
    By Usabug in forum Hobby Discussion
    Last Post: 09-10-2010, 11:59 AM
  2. Recommendations for an engraving machine
    By bsainty in forum Engraving Machines
    Last Post: 02-17-2010, 08:44 AM
  3. 3 or 4 axis machine, tips and recommendations
    By airbrush in forum DIY CNC Router Table Machines
    Last Post: 10-11-2007, 12:11 AM
  4. New machine Hardware recommendations?
    By searcue in forum Linear and Rotary Motion
    Last Post: 06-06-2006, 02:58 AM
