588,338 active members*
4,911 visitors online*
IndustryArena Forum > MetalWorking > Casting Metals > easy oil burner build for furnace
    Aug 2007
    69
    Smile easy oil burner build for furnace
    Hello, I have been working on building an oil burner for my small furnace. What i came up with can be made using common plumbing parts and a drill. It does need a little soldering though too. CLICK HERE to see my build web page.
    Here is a picture of it:
    And CLICK HERE for a youtube video of it lighting on kerosene:
    http://metalshop.homestead.com
    Aug 2008
    292
    oil burner
    i had a kerosene burning crucible furnace. it used a home oil burner furnace pump to pump kerosene through a oil burner atomizing spray nozzle. i used a propane burner to get to 1000F and the waste heat was used to preheat / start the kerosene til it vaporized (blue flame). atomizing spray nozzle would clog after awhile . an open hole worked if kerosene is hot enough.
    problems i had was kerosene boiler got so hot and pressure so high it pushes back toward oil pump and hot kerosene vapor damaged a pressure gage and vaporized kerosene steam came out. i shut burner fan and oil pump off but kerosene boiler stayed hot and vapor kept leaking, i slowly backed up expecting an explosion that would frankly do huge damage. i was lucky and nothing happened. i learned the value of 2 check valves both only allowing one way travel of kerosene toward furnace NOT back toward 100 psi pump.
    i had 5 gallon kerosene tank on a bathroom scale so by weight i knew how much fuel i had. kerosene burner was so hot it would burn and partially melt crucible where flame touches crucible.
    just remember that a oil burner often takes longer to shut off
    Aug 2007
    69
    Smile video of the building of the burner
    CLICK HERE to see the video I made from start to lighting it!
    Dave D
  1. Splints Furnace Build Log
    By Splint in forum Casting Metals
    Last Post: 12-03-2013, 12:28 AM
  2. Easy to build torsion box and rails
    By lgroulx200 in forum DIY CNC Router Table Machines
    Last Post: 11-21-2012, 06:37 PM
  3. Easy Build 800 x 500 x 85
    By Daniel233 in forum CNC Wood Router Project Log
    Last Post: 06-14-2011, 04:04 AM
  4. Router aluminium steel easy build
    By Bartuss1 in forum News Announcements
    Last Post: 02-06-2010, 10:09 PM
  5. Building an oil burner for my furnace
    By davidmb in forum Casting Metals
    Last Post: 11-07-2006, 12:00 AM
