586,117 active members*
3,552 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > Free Dynamic Balancer (Turbine, EDF and Prop).
    Oct 2010
    448
    This balancer is based on the design from Balancing Tool.
    I'm in the midst of building some high quality dynamic balancers and in the process thought I could help someone out who wants one if they can help me (sharing the expense of producing).
    I know someone who has one of these devices and have seen it in action, I can say that it is very good, simple to use and very accurate.
    Basically I will produce the mechanical portion of the balancer (including supplying the sensors) if someone can produce the circuit boards.
    The files to generate the PCB are attached (the author no longer produces the device/parts).
    You should be able to have any board shop make the boards with the supplied files, making a minor modification because a part has been substituted (original no longer available).
    There are also online PCB options for small quantity / prototype runs so it should be relatively painless to have boards of quality made.
    You don't have to populate the boards, making them is sufficient for me, I'm not greedy or trying to put anyone in the poor-house.
    You are welcome to contact me to discuss the matter further.
    Attached Files Attached Files
    Oct 2006
    120
    i cant make the pcb's for you (don't think my mill would be much good at high speed routing stuff) but I'm interested in your/his project. i was looking at this some years ago, but didn't get round to do anything about it.
    the one that you have seen running..... did you balance a compressor, turbine wheel etc?.
    would be nice to see a demo vid of you balancing something.
    Oct 2010
    448
    Quote Originally Posted by blighty View Post
    I did see a complete rotating assembly being balanced after verifying the balance of each individual component and was impressed at how quick the whole process was.
  1. Electric motor rotor balancer?
    By DennisCNC in forum CNC Machine Related Electronics
    Last Post: 07-18-2019, 02:22 PM
  2. fanuc om prop amplifier
    By alphatad in forum Fanuc
    Last Post: 06-23-2008, 04:14 PM
  3. DEGREEING A BALANCER ON THE PATRIOT
    By smallblock in forum Shopmaster/Shoptask
    Last Post: 03-03-2008, 03:31 PM
  4. VFD = Balancer?????
    By Helix60 in forum Phase Converters
    Last Post: 02-21-2007, 06:22 AM
  5. Replies: 0
    Last Post: 10-10-2006, 09:19 AM
