586,121 active members*
3,755 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > My billet iphone case design
    Sep 2006
    29
    Hi All,
    What do you think ? honest thoughts please, something I have designed to protect my phone more
    Apr 2010
    If you made this for yourself I think it is a nice exercise in design and milling.
    If you made it with a view to commercialisation, I'm not so convinced. My thoughts sit somewhere between "You wasted a whole bar of aluminium to produce that?", and "Too big, too heavy, too prone to damage".
    There are thousands of iPhone cases on the market, I don't think you could compete with this design. What do you see as its unique selling points?
    Jul 2010
    492
    anything solid like this could pass the shock from dropping thru to the phone. i would have a rubber case instead for that reason alone....
    Oct 2005
    672
    How does this affect the transmit/receive? Would this act like a Faraday cage?
    Regardless, it looks cool. I know machining thin sections can be tricky.
    Aug 2010
    How are you attaching the 2 halves together? I am going to be doing this with my Ipod Touch. I plan on resisting shock better with using my Otterbox rubber and plastic case underneath the billet case.
    Caprirs makes a good point. I made a case for my flip phone when i was in college using a manual mill, and it killed the signal by half...
  1. RFQ: Billet Block
    By Thorpydo in forum RFQ (Request for Quote)
    Last Post: 07-07-2011, 08:23 PM
  2. Design Question - Resin Case Floor
    By groswald in forum Momus Design CNC plans
    Last Post: 05-03-2011, 04:00 PM
  3. Request For Quote: CNC Aluminum iPhone case
    By Heather in forum Employment Opportunity
    Last Post: 03-15-2011, 06:56 PM
  4. What method should I use? Need to build iphone case prototype.
    By jason1621 in forum Glass, Plastic and Stone
    Last Post: 01-13-2011, 04:42 PM
  5. milling iphone case
    By odenflagship in forum Torchmate
    Last Post: 09-14-2010, 07:15 PM
