586,103 active members*
3,799 visitors online*
    Nov 2011
    28
    Gildemeister CTX 400E
    Need help with CNC Gildemeister CTX 400E (year 1994), the main spindle motor is making a horrible noise, so we change the 3 main bearings inside the motor, but we still getting the same noise special when the spindle runs in slow speed 300rpm, we think it’s the main spindle drive, can anyone tell me what that problem and how I can solve it (I tested the motor in a different machine runs good without no noise)
    Oct 2012
    29
    Does the machine have an automatic chuck?
    When not the chuck it's self but the pulling part is even slightly miss aligned it makes a horrible noise or vibration.
    Nov 2012
    20
    gildemeister spindle prob
    since you have swapped the motor that is eliminated - so its either the drive or the transmission stressing things out. run up the spindle to a couple thousand rpm then shut off the main power to the machine so that the spindle has to coast to a stop. if you still hear the noise the problem is mechanical. If the noise goes away your prob is in the motor controller.
    Apr 2009
    18
    Quote Originally Posted by nice-day View Post
    Hi dear
    I am cnc machine installer and working on fanuc ,Siemens,GSK system control . recently my customer was buying
    the used machine gieldmaiester ctx400 turning machine but we are not any maintenance pdf catalog and it's parameter list .
    Please send me all machine parameter and related catalog .
    My phone number is 00989142385116 for WhatsApp connection we already pay your service .
    Best regards
    Fatehi
  1. Gildemeister NEF CT 40
    By gugu in forum Mini Lathe
    Last Post: 03-26-2021, 10:06 AM
  2. Gildemeister NEF CT-60
    By ragunath400 in forum Controller & Computer Solutions
    Last Post: 05-11-2014, 08:16 AM
  3. Gildemeister CNC Lathe
    By ReallyBigDoors in forum Want To Buy...Need help!
    Last Post: 10-03-2011, 08:07 PM
  4. Maho 400E or 600E
    By HKgunslinger in forum Want To Buy...Need help!
    Last Post: 11-10-2008, 02:12 AM
  5. Gildemeister T-42
    By lonely in forum Uncategorised MetalWorking Machines
    Last Post: 10-27-2008, 01:57 AM
