603,954 active members*
3,345 visitors online*
    Nov 2011
    HAAS HL-2 Lathe tool setter
    I am preparing to teach a course at a community college on CNC controls and have a HAAS HL-2 lathe with a tool setter at my disposal. I have not used any HAAS lathe or mill in industry so this lathe is a new experience. I am well aquainted with Mazak lathes with tool setters and have adjusted them to be quite accurate.
    My problem with the HAAS is that after I have touched of the tool (X+Z) and the tool geometry numbers are altered, the new numbers are nowhere near the geometry numbers that I got by making a cut and adding the diam for X and face cut for Z. I know the G54 will alter the Z while machining.
    I would assume the tool geometry numbers (particularly in the X-axis) would be the same no matter what method you use to determine the number.
    Am I missing something unique to the HAAS control or is the tool setter not calibrated correctly?
    Thanks in advance,
    Claude
    Feb 2010
    1184
    The manual for the machine will have instructions for calibrating the tool setter. If you do not have a manual, you can download it from the Haas website.
    Nov 2011
    Thanks for the reply.
    I went to the site and found "Hass Lathe Manual 96-8700"
    Would this apply to my specific machine?
    I see on page 130 "Lathe Tool Pre-setter Alignment"
    I will be at the shop today and will try this.
  1. Tool Setter Macro for M-V60C and Metrol Setter
    By mitshack in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-02-2013, 12:08 PM
  2. Renishaw TS27R tool setter on HAAS machine.
    By JasonR in forum Haas Mills
    Last Post: 09-23-2009, 07:36 AM
  3. Replies: 5
    Last Post: 06-29-2009, 04:34 AM
  4. Tool setter macro for M-V60C and Metrol setter
    By mitshack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2008, 02:38 PM
  5. Tool post grinder for haas TL series lathe
    By L.Kiefer in forum Haas Lathes
    Last Post: 11-15-2007, 10:39 PM
