588,182 active members*
4,397 visitors online*
    Nov 2011
    28
    GILDEMEISTER NEF400EPL
    I have a problem with CNC Lathe Gildemeister NEF400 EPL, the G01 code doesn’t work, when the machine in a manual running mode G00 it works, but as soon as it moves to automatic mode G01 the spindle works but the cutting head doesn’t move (Z & X) stops totally, the machine operator did all the kind of program check everything looks fine, I’m attaching 2 pictures for the machine and the controller.
    Machinetype CNC Lathe
    Make GILDEMEISTER (Year 1983)
    Type NEF400 (No. 68094)
    167-30-0100 / 016
    Dec 2004
    150
    Quote Originally Posted by nice-day View Post
    167-30-0100 / 016
    Have you programmed a feedrate for example... G95 F0.20 The machine will not feed if a feed has not been programmed. I have not worked this machine but i have worked on other guildemeister lathes and after the machines are powered down and back up , spindle speed and feed rates have to be initialized.
    Keith.
  1. Gildemeister NEF CT 40
    By gugu in forum Mini Lathe
    Last Post: 03-26-2021, 10:06 AM
  2. Help with Gildemeister/siemens
    By turner13 in forum SIEMENS -> GENERAL
    Last Post: 04-10-2019, 06:02 PM
  3. Gildemeister CNC Lathe
    By ReallyBigDoors in forum Want To Buy...Need help!
    Last Post: 10-03-2011, 08:07 PM
  4. gildemeister lathe
    By roni21702 in forum DNC Problems and Solutions
    Last Post: 03-08-2010, 06:09 PM
  5. Gildemeister T-42
    By lonely in forum Uncategorised MetalWorking Machines
    Last Post: 10-27-2008, 01:57 AM
