586,116 active members*
3,442 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal lube system help needed
    May 2008
    4
    I'm working on an older 4020 lube system with Bijur FJB units that someone has modified (butchered/mixed up sizes etc.). I'm thinking the units should be size 00 on the screws, 0 on the gibs/straps, 1 on the Z axis flat and maybe even a 2 on the X and Y flat ways.
    Can someone give me some guidance on the proper size and placement of the metering units?
    Dave
    Jan 2007
    1389
    I thought I posted a sheet that had all the sizes on it a few years ago but couldnt find it. if I can dig it up at work I will post it.
    If you call fadal support they can email you the pdf file.
    Fadalcnc should also have the size's I think it might be in there manual section. I got some of the ones I needed from them
    There are 2 stacks of metering units. one underneath the left said of the x axis and one on top of the z head
    Jun 2009
    20
    on the older fadals the parts # are lub-0067 10 way manifold for VMC6030 saddle and lub-0068 8 way manifold for VMC6030 Z axis head - lub-0069 and lub-0070 are for VMC4020 same as above - this will get both the uper and lower manifolds with meters
    not expensive -Dave
  1. Over ride the lube system
    By chipsahoy in forum Fadal
    Last Post: 09-28-2010, 12:52 PM
  2. Fadal lube and error question
    By pman in forum Fadal
    Last Post: 11-23-2009, 02:49 AM
  3. fadal vmc 15 spindle lube
    By timo2le in forum Fadal
    Last Post: 02-17-2009, 09:44 PM
  4. Diagram of lube system
    By Hood in forum Bridgeport / Hardinge Mills
    Last Post: 07-06-2006, 09:46 PM
  5. Bridgeport Lube System
    By kewl_cat in forum Bridgeport / Hardinge Mills
    Last Post: 03-05-2006, 05:54 PM
