586,114 active members*
3,277 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > $30 RPM Improvement for LMS3900
    Nov 2011
    33
    I did a simple belt and pulley change on my LMS3900 to increase the max RPM to approx 4,150 (don't have my tachometer yet) from the 2,500 stock. Thought some of you may be interested in trying it as well.
    No machine modifications required.
    Total cost around $30
    Parts are from https://sdp-si.com/eStore/
    PN: A 6A25-032NF1508
    PN: A 6R25-M077150
    See PDFs attached
    GG67
    ** Disclaimer**
    I've made this change but do not have a lot of time running the machine with it to gauge long term bearing life but I'm willing to take the risk for improved RPM and change/upgrade bearings latter if needed.
    Attached Files Attached Files
    Mar 2011
    525
    Thank you for taking the time to posting the info!
    Kelly
    www.finescale360.com
    Nov 2011
    33
    Update
    Just a quick update, I've run the machine for about 2 hours continuous at full RPM with this set up and have not had any issues. The casting gets warm but does not seem much worse than with the stock pulley combo. This was just freewheeling not under load.
    GG67
    Feb 2011
    308
    GG67 how is the setup working? No problems? I would like to make the upgrade.
    Nov 2011
    33
    Working great, I've had no problems and have done a lot of machining with it.
    GG67
  1. NM-200 production improvement
    By robben678 in forum News Announcements
    Last Post: 12-29-2009, 04:53 AM
  2. Improvement Software
    By Ninus in forum Fanuc
    Last Post: 05-27-2009, 07:09 PM
  3. Which machine for process improvement?
    By RoboElvis in forum Waterjet General Topics
    Last Post: 02-05-2008, 03:47 PM
  4. Z improvement, Aaron, anyone
    By ozzie34231 in forum Charter Oak Automation Support Forum
    Last Post: 04-23-2006, 02:00 AM
