586,121 active members*
3,527 visitors online*
Results 1 to 7 of 7
    Apr 2009
    60
    It's finished
    Well it's finished and it works. Well 99% finished anyway....
    It'll do 275mm on each axis. Mainly cutting perspex.
    Just starting to work out cutter speeds and feed rates. At the moment it's running with the Dremel flat out and a feed of 7mm/sec which is about 1.4 ft/min. I think the rpm's are too high as the chip is very small. If i increase the feed rate the Dremel starts to run out of grunt (3mm cutter). So I should either reduce the cut depth so I can increase the feed or drop the rpm.Correct??? Would welcome any thoughts on suitable feeds and speeds.
    CNC :: IMG_1354.jpg picture by 4Lowie - Photobucket
    Oct 2006
    461
    The ideal thing is to cut at the correct feedrate. It will avoid the tip edge rubbing on the material and becoming blunt. But if you're taking really shallow cut passes, you'll only be using the lowest bit of the cutter to do cutting work... so it will wear out quicker.
    I usually cut around 9000 to 1200mm/min with a 2-flute 3mm endmill 8000rpm, up to 2mm depth of cut. That's also using compressed air to blow the chips out and provide some needed cooling. I'm unsure what a dremel can accommodate though. You might need to increase the RPM and also the feedrate to match.
    Best thing to do is to run some tests. Cut some slots and vary FR, DOC, RPM. You might break a couple of bits in the process, but you'll learn heaps.
    Jun 2010
    4256
    Heat
    Run without air once and see how hot the perspex and the cutter get. Too hot is not good!
    Yeah, you need to keep some material in the teeth.
    Cheers
    Feb 2006
    101
    Quote Originally Posted by Eclipze View Post
    Is one of those numbers a typo? 9000? 1200?
    Oct 2006
    461
    Yep... meant 900 to 1200mm/min.
    You'd need a pretty fast machine to even rapid traverse 9000mm/min.
    Usually I slot cut at slower speeds when cutting thin acrylic, i.e 3mm thick. Otherwise there is too much flex/stretch in the material from the cutting force and accuracy drops.
    Jan 2012
    That little thing is awesome, I'd love to build one for my little dremel. Any chance of getting a copy of the plans/part list? What sort of stuff have to cut on it?
    Jan 2012
    I'd drop the rpm.
  1. My 4x6 CNC, Just about finished
    By Momentz in forum Australia, New Zealand Club House
    Last Post: 05-04-2012, 12:44 PM
  2. Almost Finished
    By Kencor1 in forum DIY CNC Router Table Machines
    Last Post: 11-21-2010, 05:41 AM
  3. First CNC - 50% Finished
    By Trucks in forum DIY CNC Router Table Machines
    Last Post: 09-14-2009, 02:45 AM
  4. Finished at last (well almost!)
    By Ali Kat in forum DIY CNC Router Table Machines
    Last Post: 05-27-2009, 06:19 PM
  5. X2 cnc finished for now
    By hoss2006 in forum Benchtop Machines
    Last Post: 01-12-2007, 11:55 PM
