603,323 active members*
4,197 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Awesome base for Sherline 2000 Mill -- Free to a good home
    Sep 2004
    4
    I am moving, and no longer need an AWESOME base that I had made for my Sherline 2000 mill. I want it to find a new home.
    You can have it if:
    1. You can pick it up soon. I am moving over the weekend, so would prefer someone get it December 23 or 24th 2011. I live in Lowell, Michigan (49331) -- which is just east of Grand Rapids.
    2. You promise that you aren't going to sell it on Ebay, or sell it from scrap metal. I could do that, but want someone who would really use it.
    A friend at a tool-and-die shop made if for me. It's more than an inch thick metal, heavy. Maybe two. Never seems to show any signs of rust or discoloration, so the materia is very nice. Seems almost polished. Maybe stainless? Not sure.
    Has holes drilled and tapped to hold the mill base, as well as a series of holes drilled and countersunk from the bottom to allow you to move the column back in one inch increments by removing it from the sherline base and attaching it directly to this new base. You can really extend the Y axis movement this way, as well as adding stability and rigidity.
    It is heavy. I can lift it, but just.
    First person that can pick it up by the weekend can have it. Email me directly at carl.lance at gmail dot com
    Carl Lance
    Dec 2011
    i live too far away to pick it up, but could you post a picture? I just got a sherline and I haven't made a base for it yet
  1. Replies: 9
    Last Post: 10-08-2011, 09:32 PM
  2. CAD CAM recommendations for Sherline 2000 mill
    By rwsduc in forum Uncategorised CAM Discussion
    Last Post: 03-10-2011, 10:07 PM
  3. Sherline mill saddle to base slides
    By Reax in forum Taig Mills / Lathes
    Last Post: 09-05-2010, 03:51 AM
  4. Free to a good Home
    By crash5050 in forum Want To Buy...Need help!
    Last Post: 02-25-2010, 01:20 AM
  5. CAM Programming helps a new begynner with the Sherline Mill 2000 (2010)
    By AlfSkaar in forum Uncategorised CAM Discussion
    Last Post: 09-03-2007, 02:39 PM
