586,406 active members*
3,225 visitors online*
    Jul 2010
    27
    Help with motor tuning
    Hi everybody. I am new to the CNC. I have purchased a sherline CNC mill. I have download mach3 but it will not reset so I can use the prograam. So I downloaded mach2. It works fine. But tuning the motors seems good. I move it .100 and it moves .100 with the indicator. But when I go and run the program. It doesn't move the same eveytime. I have the X moving 2.5" after it drills the first hole and moves to the net locaation. Some times it is short about .100- .150 and times it is long +.100 to +.150 and sometimes it hits right on. Also the Z seems to get shorter with each hole it drills. I am not sure it is missing a step or I don't have the motors tuned right. Please help. I would appreciate it.
    Most likely missing steps. Lower the accel and velocities by half.
    To get Mach3 working, try toggling the active low setting on the estop pin in ports and pins, input pins.
    Nov 2008
    47
    I have a similar problem, I set up Mach 3 in Windows 7 and I can't tune the motors using the Motor Tuning and Setup dialog, The motors do nothing when I move the Velocity slider as described in the Video tutorial.
    The motors won't turn until I manually input the Velocity and Acceleration.
    How can I fix this problem.
    You use the up and down arrow keys to run the motors while in the motor tuning screen.
    Nov 2008
    47
    The simplest answers can make you look foolish!!
    It works!
    Thank you
    I'm always having a PICNIC....Problem In Chair Not In Computer!
  1. Motor Tuning
    By john1285 in forum Mach Mill
    Last Post: 06-25-2010, 02:33 AM
  2. Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
    By MDF_Markazi in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2009, 08:15 AM
  3. Motor tuning
    By br1 in forum Mach Mill
    Last Post: 03-01-2009, 02:38 AM
  4. Motor Tuning
    By Smitty911 in forum Gecko Drives
    Last Post: 10-16-2007, 10:40 PM
  5. Motor Tuning
    By dwacker in forum DIY CNC Router Table Machines
    Last Post: 05-01-2007, 03:50 AM
