586,121 active members*
3,303 visitors online*
    Oct 2010
    87
    Vibratory media question
    Can I use sand blasting media : steel grit, aluminium oxide etc, as a vibratory tumbler media ?
    Dec 2007
    2134
    You can use almost anything, it just depends on the degree of coarse or fine abrasion, and the level of polishing required. As an example I use the el-cheapo 20kg $6 bags of small crushed stones from the builders section in Bunnings, and use it dry for rough to medium sanding of steel parts. Does a mighty fine job too! And a damn sight cheaper than the equivalent roughing grits from the "specialty suppliers". Here in OZ every store is a "specialty supplier" due to the way we get reamed on products and pricing.
    I did try the $6 bags of builders sand for finer finishing also but it was fairly slow going, and I was too impatient too wait and see!
    Just try it and see would be my advice as it's basically only a sliding ratio between time, density, and parts. Aluminium oxide and steel ball bearings are a couple of very commonly used media for vibratory tumblers so I would think you'd be fine.
    cheers,
    Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  1. What media to use?
    By UBRacing in forum Mass finishing equipment/media/strategies
    Last Post: 01-03-2008, 07:19 AM
  2. Recommended vibratory media for Aluminum
    By SRT Mike in forum Mass finishing equipment/media/strategies
    Last Post: 03-30-2007, 01:46 PM
  3. MIT Media Lab in Boston ?
    By rab in forum Community Club House
    Last Post: 10-04-2006, 11:35 AM
  4. Media
    By behemoth in forum Mass finishing equipment/media/strategies
    Last Post: 01-18-2006, 01:34 AM
