586,094 active members*
3,758 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Finding spindle tool number on Fanuc OiMD
Results 1 to 10 of 10
    May 2008
    157
    Wink Finding spindle tool number on Fanuc OiMD
    Is there a way to find out the tool number that is in the spindle on Fanuc OiMD ?
    I do know the method of finding the latest T command but i want to go beyond this and find specific tool number in the spindle.
    2932
    Quote Originally Posted by yaji63 View Post
    What machine is this? If it's a Doosan I may be able to dig up the information.
    Feb 2006
    1792
    Somebody said some time back that there is a special system variable for this on Fanuc, but I cannot recall.
    May 2008
    157
    Quote Originally Posted by dcoupar View Post
    This is a Campro (Taiwan Make) CQV 1300 with Fanuc OiMD controller.
    May 2008
    157
    Quote Originally Posted by sinha_nsit View Post
    I too recall reading somewhere that there is a system variable for this but I' am unable to find it
    2932
    I found the system variable for the tool in the spindle on a Doosan HM6300 with Fanuc 31i! I believe this may also apply to the Doosans with 0iM-D.
    #1032 - #1035 are interface input signals (long). This particular one was stored in #1035. You might try reading #1032 to #1035 to see if they exist:
    #102=#1032
    #103=#1033
    #104=#1034
    #105=#1035
    In this case, #105 was 40 when T40 was in the spindle.
    May 2008
    157
    #102=#1032
    #103=#1033
    #104=#1034
    #105=#1035
    Thanks a lot. I found the Spindle tool number on one machine in #1033.
    Another machine with Fanuc OiMD controller does not have this range is system parameters ! I have asked the MTB for info about variables with interface input signals but i' am not sure whether i will get a reply from them.
    Any clue where else these parameters could be on FanucOiMD ?
    Feb 2006
    1792
    These variables do not seem to be standard features of Fanuc; their manuals do not describe these. I believe MTB defines these. So, these may or may not exist.
    May 2008
    157
    My other machine tool builder did finally output the PLC variable G53 into #1033 and now i can read the spindle tool number on both the machines.
    Thanks again for the info about Interface input signals (long) as this was the one which helped me in getting the work done by the MTB !
    Jul 2012
    yep, that exactly what i am after. we have a toyoda with fanuc oimd and i want to use the G43 H#___ Z50. so as long as tool length is entered correctly, the H offset will be right it .
  1. Replies: 6
    Last Post: 01-14-2012, 07:17 AM
  2. Tool number changes in Sprutcam
    By rhkratz in forum SprutCAM
    Last Post: 11-24-2011, 07:38 PM
  3. Locking the tool pockets to a tool number
    By KevinV_MEI in forum Bridgeport / Hardinge Mills
    Last Post: 09-18-2011, 05:55 PM
  4. 88HS tool number
    By voytek1 in forum Fadal
    Last Post: 07-18-2011, 07:03 PM
  5. Missing Tool Number
    By barbter in forum NCPlot G-Code editor / backplotter
    Last Post: 10-04-2008, 04:07 PM
