586,121 active members*
3,661 visitors online*
IndustryArena Forum > Other Machines > Commercial Products / Manufacturers Support Forums > Automation Technology Products > Why are keling ATC spindles so much more expensive than er11 spindles?
    Nov 2011
    I would imagine that the ATC spindle would cost more than the non-ATC variant, but these things are around 6-10 times the cost of the non-ATC (the er11 collet) spindles. Note that I'm comparing the k-l2200 to the kl-2200ATC and the same deal with the kl-4500 I'm assuming they have the same motor and same if not very similar bearings (could be wrong on that). I would imagine they have some pneumatic mechanism to grab the tool holder, consisting of a solenoid, a piston and some moving parts. I am just very surprised at how much more you have to pay to get a spindle compatible with an automatic tool changer... its not like the spindle comes in a package with a complete ATC system.
    I believe the huge price difference is not that the ATC spindles are very expensive, but because of how cheap the standard spindles are. I've seen 2.2Kw spindles as low as $250.
    Compare a non ATC chinese spindle vs a similar power HSD. The chinese spindle is 5-10 times cheaper. This is most likely due to the huge volumes of these being produced. There are numerous sellers on Ebay, from what appears to be many different manufacturers. I'd imagine that ATC spindles are produced in much smaller quantities. In the 5 years or so that the chinese spindles have been available, I've seen one person purchase an ATC spindle, while hundreds have purchased the standard chinese spindles.
    If you look at a standard and ATC spindle from a manufacturer like HSD, you'll see that the ATC sindle is 2-3 times more expensive.
    A chinese ATC spindle is probably 30%-60% cheaper than an HSD or Colombo ATC spindle.
    Nov 2010
    177
    Re: Why are keling ATC spindles so much more expensive than er11 spindles?
    Should I even consider a Chinese spindle? I would rather pay for a good, quality "Made in 'Merica" spindle than five cheap Chinese spindles, IF there is a REAL difference in quality or value.
    I am considering my first spindle purchase to put it into service on my PlasmaCam CNC table. I would change the bits manually. There is no ATC available for the PlasmaCam.
    Joe
  1. Any reasonably priced (cheap) spindles other than the chinese spindles?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 11-05-2014, 11:16 PM
  2. Question about Keling Spindles
    By 3dsignco in forum Automation Technology Products
    Last Post: 01-01-2010, 03:44 PM
  3. Spindles de alta qualidade.High quality spindles.
    By Newtron in forum News Announcements
    Last Post: 09-21-2009, 08:33 PM
  4. Spindles
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 02-13-2009, 05:46 PM
  5. HF spindles
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 09-29-2008, 07:00 PM
