603,855 active members*
4,044 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Best way to optimize my program
    May 2008
    665
    When doing multiple works offset fixtures, when program is completed, what is the best way to optimize it, I mean to save time for tool change by going from G54 to G55 and G56.
    ex: If I have a 1/2 end mill in the spindle, I want to do all toolpaths that use this tool for the G54, G55, G56.
    Can I use the toolpath translate function to do that.
    Thanks, Jeff
    Dec 2008
    717
    Just put the tools in order in your toolpath tree. (iow don't have all of G54 first, then G55, etc, - go by the tool - so have all of the 1/2" endmill toolpaths first, then the next tool, etc.) I'd only pay attention to the work offsets at the next level - within a tool's group, so it doesn't take the 1/2" endmill and cut a feature on G54, then G56, then back to G54, etc...(unless it makes sense to do it that way)
    Tim
    May 2004
    4519
    Highlight all of the operations in the operations manager, right click, then click on sort, then sort by tool number.
    Dec 2008
    717
    I may have misread it. I thought he was simply doing multiple operations on a part (G54 1ST SIDE, G55 SECOND SIDE, ETC)...but if you are doing the same operation over and over...then yes, toolpath translate.
    Tim
    May 2008
    665
    Quote Originally Posted by txcncman View Post
    Highlight all of the operations in the operations manager, right click, then click on sort, then sort by work offset.
    Thanks, I will see what I can do with this.
    Thanks also to WallyL7.
    Jeff
  1. Checkout this cambam file. optimize?
    By diyengineer in forum CamBam
    Last Post: 10-04-2011, 10:10 AM
  2. GCode optimize, visually edit, pick machine order, etc?
    By tdiaz in forum Uncategorised CAM Discussion
    Last Post: 04-23-2011, 07:04 PM
  3. Replies: 0
    Last Post: 12-27-2010, 09:55 AM
  4. optimize it
    By kesparate in forum Mastercam
    Last Post: 04-03-2009, 11:50 PM
  5. Software to optimize the layout of the factory
    By KAMPUZ in forum Uncategorised CAM Discussion
    Last Post: 05-27-2005, 08:47 PM
