603,940 active members*
2,217 visitors online*
    Dec 2011
    155
    Anyone ever use mist or flood?
    For those of you who cut aluminum or other metals with your routers, has anyone ever used flood or mist coolant? My porter cable router flows quite a bit of air out the bottom, so I don't think it would get into the router. I'm just wondering if anyone has tried it yet.
    Apr 2009
    5516
    I use one of those venturi-style air chillers, though my compressor is only 20 gallons and I only use it intermittantly when doing small (1/16") slots. My next build will have mist coolant...
    May 2004
    4519
    Use air blast or cold air gun (if you have the compressor to support it).
    Aug 2008
    142
    I normally cut 5051 dry, it needs no lube. When I cut 3003 I use a little WD-40 in a spray bottle.
  1. Kool Mist #77 proper mixture for flood
    By The_Tuner in forum MetalWork Discussion
    Last Post: 03-04-2016, 06:20 PM
  2. flood and mist coolant
    By azza304 in forum Community Club House
    Last Post: 08-12-2011, 08:14 AM
  3. Mist vs. Flood coolant
    By rogerfries in forum Bridgeport / Hardinge Mills
    Last Post: 08-13-2010, 09:17 PM
  4. Coolant, Flood, Mist, WD-40, etc
    By Smitty911 in forum Benchtop Machines
    Last Post: 11-15-2009, 04:15 PM
  5. Flood and Mist controls
    By shane.vella in forum Machines running Mach Software
    Last Post: 10-01-2008, 11:56 PM
