586,102 active members*
2,485 visitors online*
IndustryArena Forum > SignMaking > Signmaking Topics > Round over thin bits
    Oct 2011
    218
    Hi all , I'm on the hunt for a round over tool with bearing or similar, to edge 4.5mm acrylic , the only mini micro ones I've found still need thicker material to work, if it was just a one off I would sand but this is for a shop, looked at the dremel round over bits but don't think they will go that thin, any ideas would be greatly appreciated
    Cheers all.
    Riche
    May 2008
    667
    Hi, you should build yourself or buy a router table and use a full radius cutter, you can use it to full cut or just a small portion of it to break corners.
    This it way better than using a hand router.
    Jeff
  1. Round Over Groove Router Bits
    By wishgranter in forum CNC Tooling
    Last Post: 01-10-2012, 09:48 AM
  2. Work holding options to hold thin round work? .024, .046 etc
    By KyleH2 in forum MetalWork Discussion
    Last Post: 06-07-2010, 07:22 PM
  3. Looking for a set of router bits for wood, plastic, foam and thin aluminum.
    By bkboggy in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 04-24-2009, 05:06 AM
  4. Router bits, End mills v bits
    By bogger44 in forum Commercial CNC Wood Routers
    Last Post: 12-03-2008, 07:06 PM
  5. 2D Contour on a round OD not very round :(
    By kojack in forum Mastercam
    Last Post: 08-11-2008, 01:07 AM
