586,117 active members*
3,400 visitors online*
Results 1 to 6 of 6
    Nov 2007
    79
    set relative value to zero
    HI All
    i have a problem with set zero in relative screen (lathe machine)
    when i want to set the tool in X or Z to zero in relative the value dosen't change to zero (only in relative coordinates) the machine is
    Colchester-Harrison GE Fanuc ALPHA X Series Lathe(touch screen)
    note : i have set up refrence return to the machine after the battery became low and released APC alarm X & Z need zero return ,
    i changed the batteries and the machine works fine now except the relative zero for X& Z AXIS
    are there some parameter to change or something else?
    any suggestions, opinions or help will be appreciated
    thanks in advance
    Aug 2011
    2517
    on later Fanuc controls you can only set relative position page to zero. X and Z absolute page you can not reset to 0 manually.
    which control do you have?
    Nov 2007
    79
    thnx for ur reply fordav 11 , actually that's my problem , i need to set zero in relative page, when i work with handle and touch the tool tip at the face of work piece and select relative page to set Z axis to zero it doesn't change the value to zero neither in Z nor in X axis
    the machine is: Colchester-Harrison GE Fanuc ALPHA X Series Lathe
    (touch screen) the controller is 21i
    Sep 2010
    1230
    Quote Originally Posted by nabil_elbadri View Post
    With a Series 21i, are you doing the following to set the Relative Page Axis Position to Zero?
    1. Press POS Hard button
    2. Select REL
    3. Input Axis Name you want to Zero
    4. Press ORIGIN Soft Key
    5. Press EXEC Soft Key
    Regards,
    Bill
    Nov 2007
    79
    thnx for ur reply angelW last step i didn't do it exec
    so i will try it as soon as i got to the workshop
    thnx again for ur help guys
    Aug 2011
    2517
    relative position page axis are usually not XYZ.
    for X axis you need to press U and ORIGIN
    V ORIGIN for Y axis
    W ORIGIN for Z axis
  1. Fanuc Oi-MB Relative display
    By zooloader in forum Fanuc
    Last Post: 10-28-2021, 01:57 AM
  2. Relative coordinate display
    By SIG in forum Fanuc
    Last Post: 02-08-2008, 06:27 PM
  3. Absolute and relative
    By jorgehrr in forum CNC Machining Centers
    Last Post: 10-10-2007, 09:42 PM
  4. Fanuc 0M.. how do you zero relative?
    By OC_ in forum Fanuc
    Last Post: 02-24-2007, 05:45 AM
  5. relative position
    By Rocksalt in forum Fanuc
    Last Post: 10-24-2006, 08:17 PM
