588,390 active members*
5,712 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Stepper Holding Torque but not Jogging
Results 1 to 11 of 11
    Feb 2012
    11
    Hi all,
    I have a problem with a set up that consist of the the following gear;
    G203V
    Nema 34 - 640oz/in
    MB-03 V1 BOB
    All seems to be wired correctly, and the motor holds but wont turn when Mach3 is jogged.
    I've been through the Mach3 setup process a few times and pins/ports and other assignments seem to be okay.
    I've measured the voltage between 2/com and 3/com on the BOB and always have 4.7V when powered up.
    It would be my understanding the voltage should be 0V if there is no command is being given by Mach3. When it is being controlled I would expect a raise in voltage.
    I've played around with some of the jumpers with no success.
    Any thoughts?
    Ramon
    Jan 2010
    2141
    I am not familiar with that BOB.
    In order to check whether or not you are getting the Direction signal from Mach3, through the BOB and all the way to the G203V input, can you measure the voltage between terminal 8 and terminal 10 of the G203V, and jog Mach3 first in one direction and then in the other direction?
    You should expect to see a signal of close to 5 volts when jogging in one direction and close to 0 volts when jogging in the other direction.
    Based on the results of that test there may be additional tests that could be done.
    Feb 2012
    11
    Hi Doorknob.
    Thanks for the reply.
    I have a consistent voltage of 4.8V at 8-10 and on 9-10 at all times; when jogging + or - and static. Hmmm.
    Ramon
    Jan 2010
    2141
    You should not expect to see a change in the step signal with a multimeter, whether you monitor between pins 9 and 10 on the G203V or on the step signal pin going from the PC to the BOB. The step signal is an extremely short pulse which can only be seen on an oscilloscope or a logic probe but which will not register on a typical meter.
    The direction signal is a better one to check, because it should be "high" when jogging in one direction and "low" when jogging in the other direction (that is, if Mach3 is configured properly and your parallel port is working properly).
    So, as a next step, I would try to check the direction pin voltage at the input to the BOB (from the PC parallel port). If you do not see the voltage at that point shift when changing direction then I would suspect either the Mach3 configuration or the parallel port.
    Feb 2012
    11
    Hi Doorknob,
    Checked pins 2/25 and 3/25 on parallel port and they're reading a constant 5V.
    Jogging Mach3 has no effect.
    Mach 3 holding pulling the voltage up?
    Ramon
    Feb 2012
    11
    Hi Doorknob,
    Further to that those earlier pin combinations show 0V when Mach3 is closed down.
    Ramon
    Jan 2010
    2141
    Can you post a screen capture of your ports and pins screen?
    What version of Windows are you running?
    Are you using the built-in parallel port of your PC or a separate add-in parallel port card?
    Feb 2012
    11
    Windows 7 32
    I added the parallel port 2 weeks ago as the PC wasn't built with one.
    Screenshot attached.
    Feb 2012
    11
    Oops. Try again.
    Jan 2010
    2141
    From this point, you might need some assistance from someone who has more experience with Mach3 than I have. Your config looks OK to me, and the fact that the parallel port output pin voltage changes when you start or stop Mach3 implies that Mach3 is seeing your parallel port.
    There is a subforum here that is dedicated to Mach3 issues, or Mach3 has their own support forum. Good luck with finding your problem...
    Feb 2012
    11
    No probs. I'll try there. Thanks
    Ramon
  1. Holding Torque??
    By professor in forum Automation Technology Products
    Last Post: 11-14-2011, 02:36 AM
  2. HELP WITH STEPPER HOLDING TORQUE
    By gudgers leasure in forum Stepper Motors / Drives
    Last Post: 02-05-2011, 10:02 PM
  3. Holding torque vs rotational torque ?
    By SScnc in forum DIY CNC Router Table Machines
    Last Post: 05-06-2010, 01:41 PM
  4. Stepper Motor Holding Torque
    By matsci1 in forum Linear and Rotary Motion
    Last Post: 02-09-2010, 12:35 PM
  5. No holding torque on my stepper, she's a 1200oz!
    By Apples in forum Stepper Motors / Drives
    Last Post: 09-03-2005, 07:28 PM
