586,111 active members*
3,724 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Surfacing with a disc shaped tool
    Apr 2009
    Hi guys I'm trying to surface some horizontal ribs with an Iscar grooving cutter inside of a cylinder. Can anyone guide me on how to do so? Thanks.
    Jun 2005
    32
    define the tool . then you should use 2.5 axes closed contour procedure .
    you can pm me for more info
    Apr 2009
    Thanks for the reply. The problem was in the tool definition. I did not specify the full radius that it needed to be.
  1. File disc for CNC Huffman HS75R Tool Grinder
    By righard in forum Want To Buy...Need help!
    Last Post: 01-31-2012, 11:20 AM
  2. Shaped tool
    By jake_tb in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-03-2011, 11:59 PM
  3. Creating shaped tool
    By foxsquirrel in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-10-2011, 09:11 AM
  4. Best tool for surfacing??
    By TacPyro in forum Benchtop Machines
    Last Post: 07-10-2009, 07:53 PM
  5. Which tool bit type for surfacing aluminum with a fly cutter?
    By cnczoner in forum MetalWork Discussion
    Last Post: 01-03-2008, 08:54 PM
