586,121 active members*
3,015 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Feb 2005
    753
    End mill sizes
    I need to cut a .020" slot. Is there and endmill that would cut this? Peferably carbide. I want to do it on an indexing head. and spinning the part at the same time therefor getting a grove around the diameter.
    Who thinks this would work? Currently I lathe turn it but don't want to do that anymore.
    May 2005
    1810
    You can get endmills as small as .005", so the answer is yes.
    Pay close attention to speeds and feeds - a .020" endmill is gonna snap faster than Mike Tyson at a cheerleader convention.
    You might be better off in the lathe with a grooving insert ground with adequate side and end clearance.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Mar 2005
    988
    Yes you can get a .020 carb endmill (and even smaller). Check Robb Jack or even Micro 100. There are many others as well.
    Will it work?... Yes, but why would you want to? A groove like that is much faster to run on a lathe, consistent, longer tool life, etc.... I'd think you'd be happier with parts on the lathe than milling it.
    It's just a part..... cutter still goes round and round....
    Feb 2005
    753
    Quote Originally Posted by psychomill
    true but my lathe is manual.. You do 2k a week on a manual mill!!! it is ridiculous. If I can put it in the mill I would be happier than a pig in **** :banana: .....
    What to do waht do to...
    May 2005
    1810
    I love running manual lathes....what's the aversion to a manual lathe to cut a face groove?
    From what you describe, the lathe is the way to go.
    Scott
    Mar 2005
    988
    Yes, but I think a big reason why you CAN do 2k a week is because its on a lathe. Put it on a mill, you may not make as many,... certainly not as quickly at any rate.
    What is the reason (besides the quantity) its a pain on the lathe?
    Aug 2005
    413
    Sounds like it's time to get a cnc lathe!
    JP
    Feb 2005
    753
    Quote Originally Posted by JPMach
    JP
    true... but if I got a mill I could do A LOT more work... That is my catch 22.
    Feb 2005
    753
    just time and exhaustion. Really it isn't time it's just tiring and I bet if all I had to do was load and press a button I wouldn't be as tired.
    4826
    If the configuration of the part is suitable, you might use a slitting saw to cut the groove in the mill. I'm not saying it is the wise thing to do, but if you are determined..... I would not waste 2 seconds considering an endmill for this type of job.
    Feb 2005
    753
    Quote Originally Posted by HuFlungDung
    no? Well the thing is.. I only have money for one type of machine right now... I got this job to do for 2k a week at $.75 soo if I can do it decent money.. but I want to have a mill cause I can do a lot of other jobs with it also.... :\ I dont know.. It is just a groove
    why wouldn't you use an end mill?
    Mar 2005
    988
    I'm with Hu on this one. If you're 'determined' to mill it, I'd go with a saw.
    Yes, if you got a mill you could do a lot more work (at least a lot more different type of work). However, cutting a groove on the OD of something that can be held in lathe is not exactly the right direction in my mind (unless you only had a mill and not a lathe). Time is money. Besides, what makes you think that loading 2k parts on a mill to cut a groove is less exhausting than loading 2k parts on a lathe? Not to mention, for this app., the lathe is 10x easier to set up and get going....
    Mar 2005
    988
    There's a few things to consider here. We don't know what material you're working with, the depth of the groove, and the OD of the part (or dia of groove). But for the most part, a saw will outlast the endmill in most apps for grooving as well as being able to feed it faster through the cut.
    Feb 2005
    753
    cause on the lathe (MANUAL) I have to cut the grove. then I center drill then drill for a tap. Then I take it out. Then later it goes on a manual mill for tapping..
    If I could eliminate the two set ups and just go face groove then load it in the vise and center drill, drill, tap and do that while just pressing a button would be A LOT easier than waiting for it to drill and everything. It gets aggravating. I rather spend the same time in front of the machine not doing work then actually doing work. Then in between cycle times I could do something... the 30 seconds or whatever...
    4826
    So is it a face groove in the end face of a part?
    I understand how you get aggravated and tired doing this style of work The trick is to design a process that is easy to load, and this might require spending some money.
    If you have the option to hold the part with a fast acting 5C collet, in both lathe and mill, this makes loading quick and easy. I'm just guessing that you could do all the spot, drill and tap operations in the mill, with a quickchange tool holder setup. However, it does require a bit of care to get the hole accurately placed in the the center of a shaft held in the mill. A vertical/horizontal 5C collet fixture is a good choice for a mill fixture for round objects.
    Mar 2005
    988
    Again, assuming a few things here. I agree with Hu, process has a lot to do with this. Instead of only tapping on a mill, I'd just use a drill press with a tapping head and float the thread for example... takes seconds and next to no "set up".
    Mar 2004
    1306
    If you center dill and drill the hole on the lathe, why are you not also tapping the hole on the lathe?
    Calculate how many inches of groove your 2000 pieces entail, and divide that by the number of mm a 0.020" carbide end mill will do (be conservative, as the failure mode of that 0.020" is probably going to take a piece to scrap pile with it). That is how many tool changes you are going to need to do, and how many expensive fragile little mills you need.
    Have you thought of making up simple stops for the saddle and tailstock? This part sounds like the sort of job old manual turret lathes spat out by the hundreds of thousands.
    Regards,
    Mark
    Mar 2005
    1136
    Quote Originally Posted by MBG
    with a simple throughput model, you've got to identify and analyze the constraint, or bottleneck. In machining, its often material removal rates, i.e. basic reason the commercial world went to carbides.
    In this instance, the basic constraint (as I see it anyway) of the actual cutting op is tool rigidity/support. With a .020 end mill, you got to be taking a very tiny chip. In the lathe, you can have an inch of support underneath the tool and therefore can take a much bigger chip. No comparison lathe will have a higher throughput (assuming loading/unloading is basically the same) – this is with HuFlung wouldn’t waste time considering it.
    if this is a single operation, and we’re not talking some super fancy automatic loading cnc machine, what advantage does cnc have over manual?? Lock the x axis, set a stop on the y, load the part, feed into the stop, next.
    May 2005
    1810
    To do 2000 in one week is going to be a serious chore on one machine unless you are working 18 hour days.
    18 hours a day X 7 days a week = 126 hours = 7,560 minutes (without a break...no bathroom, no lunch, no broken tools or problems)
    2000 parts in 7,560 minutes = a little less than 4 minutes each.
    I think you need another machine or two and some help! That's a lot of parts and a lot of operations!
    Scott
    Feb 2005
    753
    Quote Originally Posted by mxtras
    Scott
    and it takes me about that.. but I do have help ....
Page 1 of 2 12
