586,113 active members*
3,393 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > damn message "Check Spindle Lube, Way Lube and Air Pressure"
    Nov 2007
    68
    dear all,
    i'm new in fadal..... i have 1992 vmc4020 (CNC88HS)
    every time i try to run the machine in AUTO mode, i get the message "Check Spindle Lube, Way Lube and Air Pressure" ..... i do not know why !!!!
    i checked spindle lube, way lube and air pressure, and they have no problems at all.
    the air pressure is 6 bar, spindle oil tank is filled and the oil way lube is working fine.
    how to run my machine in Auto mode while this damn message appear every time i hit start button????????
    also i'm new in Fedal, so i need any one to explain to me in details the steps to type & run a program in AUTO mode.
    thank you all in advance
    900
    You may have a faulty lube tank switch, draw bar air valve switch, etc. Any air device can produce a bogus signal that results in this message. This will be a classic witch hunt. Good luck.
    Neal
    Jul 2009
    317
    If you machine has Mist spindle lub, there is a black floating sensor; On top there is a square box, remove it and find the red and black wires and check the 5vdc; also the 2 yellow wires for continuity. Same for the way luber.
    Nov 2007
    68
    @ denmar
    thanks for your reply ... if you have a photo for this sensor or this box will be so helpful .... many thanks in advance.
    regards,,
  1. re Spindle Lube and Lube Pump
    By robkuhi in forum Tree
    Last Post: 10-24-2011, 06:49 PM
  2. Low Lube/Oil Pressure VF2
    By jstucken in forum Haas Mills
    Last Post: 10-28-2010, 02:17 AM
  3. LOW LUBE PRESSURE alarm
    By CORBIN92087 in forum Haas Mills
    Last Post: 08-11-2010, 03:47 PM
  4. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
