586,058 active members*
4,208 visitors online*
Results 1 to 9 of 9
    Nov 2009
    50
    Which Plasma Cutter Would You Pick?
    I usually cut a lot of 18 gauge cold roll. I also cut a lot of 16 and 14 gauge hot rolled. I sometimes cut 12 and 10 gauge hot roll. Every once in awhile I'll cut 1/4" sheet, or cut holes in 1/4 thick 3"x3" square tubing. I'd like to be able to 3/8" hot rolled with ease, but I've never cut 1/2" plate. Never needed to. I also cut a lot of 22 gauge galvanized. Most of my continuous cuts are under 300 to 400 inches.
    I've been using a TD Cuttmaster A40, but it eats consumables like no tomorrow.
    I've decided to build a table using Precision Plasma's gantry, which I ordered this evening, but I need to buy a plasma cutter now and I'm not exactly sold on anything yet.
    I was leaning towards a Hypertherm Powermax 45 unless someone has a better suggestion. My budget is the $2500 range.
    I'm curious about consumables too. I've been paying $6 a nozzle (tip) and $9 to $10 per electrode with the TD A40
    Thanks.
    4
    You are right in thinking about the PM45. That would be my recommendation for the thicknesses that you are cutting. I own two PM systems and highly recommend them to anyone. The price on consumables should be slightly less with a far longer life span, compared to your current cutter. IE cheaper to run.
    Chris
    Jan 2011
    I LOVE my PM45.
    Carl
    Jun 2004
    6618
    I haven't used mine yet, but that is the one I went with too. It has the built in port to aid in connecting to the THC I bought as well. Sweet.
    I read lots of reviews and saw very little negative on the PM45.
    Lee
    Jul 2011
    86
    I use my PM45 regularly with 1/2" and 3/8", I cut some 3/8" and showed the same part to someone that was cut with a laser and they could not tell the difference...
    Dec 2011
    My everlast plasma has worked as good as my buddies Miller, and for about 1/4 the price. Will be hooking it up to my cnc table in a few weeks.
    --John
    Aug 2010
    I researched a bunch of cutters and went with th PM45. Glad I did. Haven't had one problem with it yet (knock on wood).
    Sep 2011
    54
    Hypertherm ! hypertherm!! hypertherm!!!
    Mar 2009
    924
    I love my PM-1650!
    www.metaltechus.com
  1. CNC Laser cutter versus CNC Plasma cutter?
    By squale in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2020, 02:14 AM
  2. CNC Plasma Cutter, Laser Cutter, Water Jet
    By antsals in forum Waterjet General Topics
    Last Post: 03-11-2011, 01:56 PM
  3. My new Plasma Cutter
    By Grobschmied in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-14-2009, 07:02 PM
  4. Which plasma machine do I pick?
    By HMD in forum Waterjet General Topics
    Last Post: 10-10-2007, 08:35 PM
