588,195 active members*
4,899 visitors online*
    Feb 2012
    Tool carousel problems
    My Yang cnc mill's carousel will just go around and around at a tool call.
    Jan 2011
    Does the machine have a Mits control?
    Tool changes and carousel operations are done thru the PLC and
    its ladder.
    Are you getting an alarm on the control? If so what does it say
    A likely cause is that there's probably some type of sensor that
    reads from the tool carousel and if operationg normally would send a signal to
    the PLC that it found the selected tool station. If the sensor is bad, or there
    are other problems with the ATC, the machine would behave as you described.
    How did you do the tool change?
    Feb 2012
    Yes it has a MIt control. But I just got it running again and I only need one tool to do the job I'm on. I'm not going to mess with the tool change issue until I finish this job.
    A couple of days. I'll post more then. Thanks for the interest.
  1. VF-2SS Tool Carousel Problem
    By JoBwan in forum Haas Mills
    Last Post: 05-25-2011, 07:07 PM
  2. Biesse tool carousel
    By Nathan.fisher in forum CNC Tooling
    Last Post: 03-11-2011, 07:32 AM
  3. Tool Carousel Operation
    By rbcmetalwork in forum Sharp CNC
    Last Post: 12-30-2010, 09:16 PM
  4. Carousel Problems!
    By gamila in forum Fadal
    Last Post: 01-04-2008, 03:41 PM
  5. Carousel Problems
    Last Post: 11-06-2007, 05:52 PM
