586,112 active members*
3,111 visitors online*
    Mar 2007
    122
    COMPACT FLASH CARD
    I knew the 1GB 80x Transcend Compact Flash cards that I bought would work. I was able to get them to work on all our machines 0i-mate-MD, MC, 0i-MD, MC, 21i-MB, 18i-MB and 31i-MA. I ended up formatting them in our old Nikon E990 camera. They all worked after doing that, from dataserver to DNC to punching out parameters. This wasn't the solve I was looking for but it works for now.
    Jun 2007
    25
    TO FORMAT A COMPACT FLASH CARD FOR MACHINE USAGE:
    I found the following to work on an 4gb cf cards....
    TO FORMAT A COMPACT FLASH CARD FOR MACHINE USAGE (FANUC 15,16,18, OR 21):
    THE CARDS MUST BE IN FAT FORMAT, OR THE MACHINE WILL HAVE A 1010 ERROR MESSAGE. ON A CARD LARGER THAN 2GB, THE CLUSTER SIZE MUST BE 64K.
    USE WINDOWS EXPLORER TO TO CONFIRM BY RIGHT CLICKING ON THE DRIVE LETTER WHERE CARD IS LOCATED.
    WINDOWS EXPLORER FORMAT MIGHT NOT HAVE THE OPTION TO DO THIS.
    AT THE MS-DOS COMMAND PROMPT(FOUND UNDER ACCESSORIES)
    TYPE IN, WITHOUT THE QUOTES,CHANGING THE DRIVE LETTER AS REQUIRED: "FORMAT E: /FS:FAT /A:64K", THEN PRESS ENTER TO EXECUTE COMMAND.
    THE FORMATTING PROGRESS SHOULD BE INDICATED WITH AN INCREASING PERCENTAGE UNTIL DONE.
    IF THE PC PROMPTS TO CONTINUE WITH FORMATTING, TYPE IN "Y".
  1. COMPACT FLASH CARD
    By ben_heinman in forum Fanuc
    Last Post: 04-14-2020, 12:45 AM
  2. Fanuc Compact Flash to USB
    By Coyote553 in forum Daewoo/Doosan
    Last Post: 07-22-2011, 02:21 PM
  3. Compact Flash
    By jdgromi in forum French
    Last Post: 01-30-2010, 06:38 PM
  4. Run program from compact flash
    By fomaz in forum Fanuc
    Last Post: 10-20-2009, 08:27 PM
  5. Compact Flash to IDE/ATA adapter?
    By DennisCNC in forum Computers / Desktops / Networking
    Last Post: 11-05-2007, 05:27 AM
