586,069 active members*
3,389 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > trying to load program skips LOADING Onnnn and goes to floppy done!!
Results 1 to 7 of 7
    Mar 2012
    trying to load program skips LOADING Onnnn and goes to floppy done. the file shows in the directory but shows nothing when selected.
    May 2004
    4519
    What happens when you try to copy a file from the machine to the floppy?
    Feb 2007
    664
    Is there data in the file on the floppy?
    Mar 2012
    there is data on the file. if i look at th .nc file on my pc it looks fine. these jobs have run in this cnc before. Looks like it writes to the floppy fine also.
    Mar 2012
    thanks guys for all the replies but after looking at the file that i wrote to the floppy i discovered it had no file extension so i took the .nc extension off my file and it loaded fine. I don't have much experience with cnc's thanks for bearing with me. I run a plastic injection molding shop and my toolmaker left and really had no idea what i was doing wrong.
    Mar 2010
    1852
    Quote Originally Posted by MattOrganek View Post
    Glad you got it. Believe it or not, some machines can act weird. Had one at a previous work place that would not take programs with the correct file extension and had to use a different one.
    Have fun--Mike
    Aug 2010
    579
    Haas Factory Support
    Haas machines require file extensions of .nc or .txt or a few others. It is possible your file was called o1234.nc.nc where the second .nc is the file extension. This problem can be hidden in Windows by a setting. To show file extensions in Windows, go to a folder. Press Alt to bring up the toolbar if it is hidden. Go to Tools->Folder Options. Click the View tab. Uncheck the Hide file extensions box (About the 8th one down).
    Ken Foulks
  1. How do I load and execute a program off of floppy
    By bill guinn in forum Milltronics
    Last Post: 11-18-2020, 05:35 AM
  2. Can't load program from floppy
    By dresda in forum Milltronics
    Last Post: 07-24-2011, 03:04 AM
  3. My Program Skips Lines
    By DroopyPawn in forum G-Code Programing
    Last Post: 11-22-2007, 09:26 AM
  4. Saving Work and Tool off-sets to floppy for later loading ?
    By iMisspell in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-29-2006, 05:09 AM
  5. Loading from floppy in to controler.
    By Ken_Shea in forum Haas Mills
    Last Post: 09-17-2005, 05:43 PM
