588,129 active members*
4,963 visitors online*
Results 1 to 6 of 6
    Nov 2011
    G71 CANNED CYCLE
    We machine alot of inconel. we have started using ceramics which work great, but each pass has to be at a diffrent depth of cut. is there anyway to vary the depth of cut in the G71 cycle. i have had to go back to line by line programming which is very bothersome and time consuming. Ceramics tend to be a picky bread by nature. for example if i took a depth that was .005 to deep it requires a complete program change. NOT COOL!! if there is any suggestions please let me know.:tired:
    May 2004
    4519
    If you have macro b enabled on your machine you can write your own macro.
    Aug 2011
    2517
    urgghh. inconel is bad stuff.
    On our inconel jobs we used to use Iscar IC907 inserts with good tool life. thankfully we don't do that B.S. anymore.
    if you want tool control you must program the cuts long-hand.
    but why do you need to change the depth of cut? just rough it then finish it with a different tool and play with the offset until you achieve your size.
    May 2007
    1003
    Quote Originally Posted by fordav11 View Post
    Probably because he doesn't want to notch the insert. Should translate to longer tool life. Same thing can happen with carbide inserts.
    jking, I'm sure you already know from the previous replies that the answer to your question is "No".
    Feb 2006
    1792
    A crude way of doing what he wants is to use several independent G71 cycles after splitting the cut diameter into several parts. Each G71 can use different DOC.
    Mar 2009
    39
    We've used kennametal CNMG 432s KC5010 with some success in the past, but it all depends on which grade of inco you're cutting, imho.
    No, really, just my .002"
  1. Need Help with a canned cycle
    By gtkemp in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-07-2011, 05:12 AM
  2. TL-2 IPS Canned Cycle
    By gtkemp in forum Haas Lathes
    Last Post: 06-06-2011, 01:58 PM
  3. G83 Canned Cycle
    By jammer66 in forum Fanuc
    Last Post: 02-01-2011, 12:15 PM
  4. Canned cycle
    By tsaladyga in forum Post Processors for MC
    Last Post: 08-30-2009, 12:31 AM
  5. Canned OD cycle?
    By VWbmx in forum Haas Mills
    Last Post: 06-05-2009, 06:17 PM
