603,392 active members*
3,184 visitors online*
    Jul 2007
    82
    Unhappy soft to engrave on cylinder
    Hello everybody,
    I'm looking for software able to produce code to engrave text, numbers on the cylindrical surface. I know mastercam can do it, but my budget is tight. Maybe someone know some software able to wrap X,Y surface around the cylinder to make it X,Y and Z, I don't have c-axis available. Thanks a lot for any help.
    May 2004
    162
    cylinder
    Quote Originally Posted by maximusek View Post
    Hello everybody,
    CNCwrapper will do the trick. Nicely priced at $20.:wave:
    May 2004
    4519
    How are you going to rotate the cylinder? Or do you propose to confine the engraving to a certain number of degrees to top dead center?
    Jul 2007
    82
    Quote Originally Posted by p38nut View Post
    thanks, I'll try it today.
    Jul 2007
    82
    Quote Originally Posted by txcncman View Post
    That is the problem, I cannot rotate a cylinder. Previous engraving was done by some guy, before I arrived, I don't even know what soft he has used. It looks to me every single digit or letter is made out of bunch of little steps described by X,Y and Z. Normally I would use spring loaded tool and program only X and Y, but I don't have it
  1. Not Sure What this air cylinder does?
    By CATCH22 in forum Uncategorised MetalWorking Machines
    Last Post: 01-02-2012, 12:19 AM
  2. how to engrave
    By cob in forum Mastercam
    Last Post: 10-17-2008, 08:51 PM
  3. unwrap cylinder to engrave on o/d
    By Capt Crunch in forum Mastercam
    Last Post: 04-23-2007, 01:18 AM
  4. Replies: 1
    Last Post: 12-29-2003, 02:06 AM
