586,110 active members*
3,186 visitors online*
    Jan 2010
    7
    Burny 2.8 controller parts
    Does anyone have any parts for a Burny 2.8 controller?
    I am using this controller on a plasma cutter and when the machine cuts in either just the y direction or just the x direction it cuts fine. When it needs to travel both in the x & y direction, like a miter is when the machine stutters and creates a jagged cut.
    Also I used to be able to download from my pc to the controller at 2400 baud, but I had to set it to 1200 baud for the entire part to load.
    Any ideas?
    Oct 2010
    71
    This could be as simple as the speed settings for the x axis and y axis are not matched. Run the Burny speed calibration routine and see if this helps. Unfortunately its been a long time since I used a Burny controller so I cant remember where to find it. I do have some parts for a Burny V though.
    Regards
    Ian
  1. Need Siemens 802C Controller Parts
    By LaysMachinist in forum SIEMENS -> GENERAL
    Last Post: 02-22-2011, 04:24 AM
  2. anyone got burny 2.5 parts???
    By xjdubber in forum Waterjet General Topics
    Last Post: 09-15-2009, 01:11 PM
  3. Dyna DM2400 - need controller,parts
    By base2 in forum Benchtop Machines
    Last Post: 07-16-2009, 01:19 AM
