586,032 active members*
2,993 visitors online*
    Jan 2007
    103
    My Bore has a taper ??
    Any ideas guy? (and Gals)
    when boring my bore diameter is coming out tapered.
    check lots of stuff on the machine and everything seems ok.
    when I bore 30mm to 60mm depth my bore comes out bigger, the deeper I go???
    At first I thought it was boring bar deflection, but that would cause it to be smaller diameter, the deeper I go....
    Any ideas???
    May 2004
    4519
    How much taper? What lead-in angle on your tool? Tool could be digging in as it cuts. Could be misalignment of machine. Do you also get taper on OD? Could be part push off at a greater distance away from chuck. As the cut gets closer to the chuck it become more rigid.
  1. Difference in Female Taper angle using Taper Cutter
    By Buntron in forum Material Machining Solutions
    Last Post: 06-07-2011, 06:53 AM
  2. NPT Taper-to-Straight-to-NPT-Taper Thread
    By bdyenter in forum MetalWork Discussion
    Last Post: 09-16-2009, 02:10 PM
  3. SL10 id bore taper?
    By FUN4ME in forum Haas Lathes
    Last Post: 03-13-2009, 07:55 PM
  4. Macro Programming for Taper Bore machining
    By yaji63 in forum G-Code Programing
    Last Post: 05-22-2008, 04:26 AM
