603,793 active members*
3,558 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > FreeMill vs VisualMill Std
Results 1 to 7 of 7
    Mar 2012
    75
    How similar are Freemill and VisualMill? If I learn the free one first will VisualMill be very similar with just added options?
    35494
    Freemill is probably 1% of Visualmill.
    And there's really nothing to learn in Freemill, as there aren't really any options.
    You load your model, select your tool, and export your g-code. Also, I think Freemill is about 10 years old.
    I don't think you'll find much similarity at all.
    Jan 2004
    3154
    Visualmill has demo you can download.
    www.integratedmechanical.ca
    Apr 2009
    5516
    Freemill is a one trick pony. A good one, but extremely limited. If all you do are stl relief files, it may be fine, but if you want to do any geometry-based machining, well there are other free stuff.
    VisualMill is capable of so much more there's really no comparison.
    Jul 2004
    12
    Quote Originally Posted by louieatienza View Post
    louieatienza, what other free software would you recommend?
    Jan 2007
    1795
    free mill is a cool stuff.. its import directly solid from rhino..
    and of course stl too..
    it makes not that known jaggy toolpath.. it works directly of the meshmodel..
    but it is free so we cant complain it has no features.. if there are projects you can run in one pass, then it works very well..
    possible works same way than that 1 percent of visualmill.
    Apr 2009
    5516
    Quote Originally Posted by d.miller View Post
    Having demoed a few, it's tough to recommed a CAM. It depends on what kind of work you're doing. For 2.5D work, you might be fine with PhlatScript, a plugin for SketchUp. For 3D and multi-axis work, CNC Toolkit is very powerful though the learning curve may be high. You might want to look into HeeksCNC as well. But my experiences have been that free software usually come with more tradeoffs or compromises, and you'll have to decide whether you can live with them.
  1. Inventor to Freemill
    By mishawaka in forum Autodesk
    Last Post: 01-09-2012, 11:18 PM
  2. FreeMill
    By cncadmin in forum Visual Mill
    Last Post: 07-28-2011, 08:11 PM
  3. Freemill 2-sided milling
    By Gosa in forum Uncategorised CAM Discussion
    Last Post: 07-09-2010, 09:55 PM
  4. FreeMill Errors
    By BlueFin in forum Uncategorised CAM Discussion
    Last Post: 06-15-2010, 04:05 AM
  5. Can you resize in Freemill?
    By teamtexas in forum Uncategorised CAM Discussion
    Last Post: 02-24-2009, 03:15 AM
