Is anyone out there clipping the back of a thread into a relief groove? I've been doing this with a G76 generated by Mastercam. The code looks like this for an external thread :
N6(CLIP BACK)
G54
G00 T0303
G97 S300 M03
G00 X3.16 Z-1.48 M08
G76 P010100 Q0050 R.005
G76 X2.51 Z-1.775 P1250 Q0400 R.1703 F.1667
M09
G00 X8.0 Z7.0
M05
M01
Basically, I'm using a grooving insert programmed on a -30 degree taper into the relief groove. This works really well after the front thread clip is proven, I can calculate the start point for the back clip. However, the tool is retracting out of the cut too quickly and it leaves a small burr at the end of the thread.
Is it possible to use a G32 and program the clipping tool to enter the relief at -30 degrees and then continue to the end of the relief at 0 degrees?
