603,930 active members*
4,907 visitors online*
    Jul 2009
    419
    stainless balls "freeze" in tub
    Hey folks,
    I sometimes get the stainless steel balls I use in my vibrating mini tub in a frozen situation: All neatly lined up in perfect order. This literally freezes all movement.
    Is there anything I can do to prevent this? Like making the tub irregular or something? Or turn the walls in to something rubbery?
    Sven
    http://www.puresven.com/?q=building-cnc-router
    May 2004
    4519
    Use a mixture of sizes so they can't line up in a locked matrix?
    Jul 2009
    419
    I think I solved it:
    Added a rubber lining to the tub. All profesional machines have it, I did not.
    Sven
    Sep 2012
    1543
    Add Dish Soap, could work? I know it does for ceramic.
  1. WTB: 18" diameter .125~ wall stainless tubing, 18" long piece
    By m-134b in forum Want To Buy...Need help!
    Last Post: 11-01-2012, 06:20 AM
  2. Machining flats on stainless shaft, "banana" issue
    By Pharkas in forum MetalWork Discussion
    Last Post: 01-30-2012, 06:37 PM
  3. RFQ: Stainless Steel rings 2" OD 1.5" ID
    By bobber bill in forum RFQ (Request for Quote)
    Last Post: 06-18-2011, 08:27 PM
  4. Replies: 6
    Last Post: 06-24-2008, 01:14 AM
  5. I need 1 7/8" aluminum balls
    By carbidecraters in forum Employment Opportunity
    Last Post: 12-15-2006, 08:14 PM
