586,123 active members*
3,426 visitors online*
    Question Software change request
    Using Mach3.
    I'm not sure if I'm doing this right, but when I go to zero a tool and set the offsets for my part location, I have to click the Jog % way down, sneak up on my part, then click 30+ time to increase the jog to do something esleware!
    Could you please place a max button or a key combo like for the jog, that would pop it back to 100%?
    ( If I only had a Manual Pulse Generator & a pendant! :tired: )
    Thank you,
    Eric A. Arnold
    Hold down shift while jogging for fast jog. Set your slow jog to something like 5%, hold down shift and jog down close. Then use the slow jog to get your zero. Hold down shift to jog quickly back up.
    Thanks for the reply Gerry, I'll try that!
    Eric
