588,506 active members*
6,323 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Special ID thread. sp-400 "M" type thread 8TPI
    Feb 2012
    HI. I am working on a prototype job and need some help. There are three pieces (Delrin) to the assembly-I think it comes together as a valve for wine barrels, some type of valve for wine. Anyway, the valve body calls for a "sp-400 "M" type thread 8 TPI". This is an ID thread. This drawing is poor, but it calls 3 dimensions in that area, 1.750 OD, 1.650 ?, and 1.550 ? The model is in .stp format and I cannot open this one-corrupt file.
    I think this thd might be similar to a plastic gas can, or some other irregular thd with a unique application. I would appreciate any info. I am only making the part with the ID thd. Need threadform profile, minor dia, and maybe info for an od thd so I can make a gage.
    I am so glad I signed up on this site-there are so many friendly, smart people who have helped me a number of times.
    Thanks so much.
    sp-400 "M" type thread 8 tpI---ID thread
    May 2004
    4519
    Only information I could find is here:
    Type M - Straight Swivel Fitting - External Thread
    And here:
    http://www.hammelmann.de/PDF_english...sting_guns.pdf
    Also this:
    Modified Buttress Thread
    Commonly referred to as “M?style. The modified buttress thread was developed, with a 10 degree pressure angle, to offer more closure-to-bottle thread contact. Found here: http://www.kenplas.com/topic/glossary/plascap.aspx
    Finally: bags or bottles with sp400 38mm threads material polypropylene coupling and Found here: http://www.who-sells-it.com/cy/colde...-fullsize.html And here: http://www.who-sells-it.com/cy/colde...read-caps.html
  1. Replies: 14
    Last Post: 11-13-2015, 02:57 AM
  2. Small CNC build thread 20" x 18" x 4"
    By metalworkz in forum DIY CNC Router Table Machines
    Last Post: 01-15-2013, 03:29 AM
  3. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  4. V18.0 Spiral Thread post has no "Z" Output
    By twt in forum BobCad-Cam
    Last Post: 09-10-2011, 02:58 AM
  5. Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori Seiki lathes
    Last Post: 07-19-2010, 08:59 PM
