588,225 active members*
4,525 visitors online*
    Apr 2012
    Milling an open pocket
    I know I'm doing something wrong but I can't figure out what. I have a 2" by 4" block and I'm milling an open pocket .500 deep with a .250 radius all around. In the corners I always have a small triangle of material left that I need to remove somehow. What is the "trick" to milling this feature.
    May 2004
    4519
    Doh! Draw a picture and upload it here.
    Oct 2011
    12
    Use a 1/2 ball end mill (for at least the last 1/4 for width.
    If the pocket is very big, I'd probaby do it in two stages, take out the middle with a square end mill, leaving just a smidge more than 1/4 on all sides to remove with the 1/2 ball end mill. Only real trick will be to get the finishing pass at exactly the same depth as the floor of the open part.
    That'll leave you with a 1/4 radius fillet in all internal edges.
    Jim
  1. machining an open pocket
    By winaa in forum BobCad-Cam
    Last Post: 07-29-2011, 07:18 AM
  2. pocket milling help
    By multiplex in forum WoodWorking Topics
    Last Post: 03-24-2010, 06:25 PM
  3. Pocket Milling HELP!
    By 12learn in forum MetalWork Discussion
    Last Post: 10-08-2009, 02:15 AM
  4. open pocket
    By camtd in forum Mastercam
    Last Post: 08-07-2007, 08:24 PM
  5. Open Pocket
    By camtd in forum EdgeCam
    Last Post: 10-23-2006, 07:09 PM
