586,121 active members*
3,675 visitors online*
IndustryArena Forum > CAM Software > Vectric > Post Processors > Which pp to choose for arduino grbl?
    Apr 2006
    40
    I am going to use an arduino with grbl to control my cnc. Which post processor can I choose to generate the correct gcode?
    Mar 2021
    Re: Which pp to choose for arduino grbl?
    My experience with GRBL has been good overall.
    I have used Mach 3 as a post and edited the g-code file to remove tool change commands.
    Several G-code senders will report back errors that GRBL doesn't like. Usually just deleting the offending line will allow it to run.
    Good luck with your endeavors.
    Apr 2005
    304
    Cool Re: Which pp to choose for arduino grbl?
    I use the attached one.
    Just remove ".txt" from the file name and place it in the PostP folder (or My_PostP folder).
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  1. Anyone have GRBL running on Arduino Nano?
    By hondaman900 in forum Open Source CNC Machine Designs
    Last Post: 04-20-2015, 08:10 PM
  2. Interfacing Arduino + GRBL with 3020 control box
    By dannystaple in forum Open Source Controller Boards
    Last Post: 02-05-2014, 10:01 PM
  3. DIY CNC Router - Arduino + GRBL - Question about accuracy - integer precision?
    By vitaminrad in forum Open Source Controller Boards
    Last Post: 01-09-2014, 10:10 PM
  4. Solidcam Post-Processor for Arduino GRBL
    By jlcorzo in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-13-2013, 09:36 AM
  5. Should I use LinuxCNC or grbl/arduino?
    By CptanPanic in forum LinuxCNC (formerly EMC2)
    Last Post: 04-23-2012, 07:06 PM
