586,357 active members*
3,484 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Parameter problems- part count not working
Page 1 of 2 12
Results 1 to 20 of 27
    Apr 2011
    50
    We have a Hardinge Conquest ST225B and had some major unexplainable parameter issues. Our maintenance team got the machine back up and running but left it with a few errors through out the parameter settings. One problem is the part count is no longer even displayed when the "POS" button is pressed along with The power time, cutting time, cycle time etc. are all at zeros under "offset settings". This is not a new machine to us and have at one time had everything working till one day everything went haywire. HELP Please and Thank You!!!!
    Jul 2010
    369
    Is the part count showing Zero or not there at all?
    Apr 2011
    50
    It is not there at all but use to be.
    Jul 2010
    369
    Have you ran any parts?
    If not try a 'MDI" input of M30, and just see if the part counter shows up.
    Strange situation you have there.
    What Fanuc Control exactly is it you have?
    Is it an 18T ?
    Jul 2010
    369
    Fanuc 18T Param.
    Fanuc 18T Param.
    PARAMETERS OF DISPLAYING OPERATION TIME AND NUMBER OF PARTS
    Bit
    PCM
    M code that counts the total number of machined parts and the number of machined parts0 :M02, or M30, or an M code specified by parameter No.
    6710 :Only M code specified by parameter No. 6710
    6710 M code that counts the total number of machined parts and the number of machined parts
    [Valid data range]
    0 to 255 except 98 and 99The total number of machined parts and the number of machined parts arecounted (+1) when the M code set is executed.
    Note:
    Set value 0 is invalid (the number of parts is not countedfor M00). Data 98 and 99 cannot be set.
    6711 Number of machined parts
    Setting entry is acceptable.
    [Data type]
    2–word
    [Unit of data]
    One piece
    [Valid data range]
    0 to 99999999The number of machined parts is counted (+1) together with the totalnumber of machined parts when the M02, M30, or a M code specified byparameter No. 6710 is executed.
    6712 Total number of machined parts
    [Data type]
    2–word
    [Unit of data]
    One piece
    [Valid data range]
    0 to 99999999This parameter sets the total number of machined parts.
    The total number of machined parts is counted (+1) when M02, M30, oran M code specified by parameter No. 6710 is executed.
    6713 Number of required parts
    [Data type]
    Word
    [Unit of data]
    One piece
    [Valid data range]
    0 to 9999This parameter sets the number of required machined parts.Required parts finish signal PRTSF is output to PMC when the number of machined parts reaches the number of required parts. The number of partsis regarded as infinity when the number of required parts is zero. ThePRTSF signal is then not output.
    6750 Integrated value of power–on period
    [Data type]
    2–word
    [Unit of data]
    One minute
    [Valid data range]
    0 to 99999999This parameter displays the integrated value of power–on period.
    6751 Operation time (integrated value of time during automatic operation)
    [Data type]
    2–word
    [Unit of data]
    One ms
    [Valid data range]
    0 to 60000
    6752 Operation time (integrated value of time during automatic operation)
    [Data type]
    2–word
    [Unit of data]
    One minute
    [Valid data range]
    0 to 99999999This parameter displays the integrated value of time during automaticoperation (neither stop nor hold time included).
    6753 Integrated value of cutting time
    [Data type]
    2–word
    [Unit of data]
    One ms
    [Valid data range]
    1 to 60000
    6754 Integrated value of cutting time
    [Data type]
    2–word
    [Unit of data]
    One minute
    [Valid data range]
    0 to 99999999This parameter displays the integrated value of a cutting time that isperformed in cutting feed such as linear interpolation (G01) and circularinterpolation (G02 or G03).
    6755 Integrated value of general–purpose integrating meter drive signal (TMRON)ON time
    [Data type]
    2–word
    [Unit of data]
    One ms
    [Valid data range]
    0 to 60000
    6756 Integrated value of general–purpose integrating meter drive signal (TMRON)ON time
    [Data type]
    2–word
    [Unit of data]
    One minute
    [Valid data range]
    0 to 99999999This parameter displays the integrated value of a time while input signalTMRON from PMC is on.
    6757 Operation time (integrated value of one automatic operation time)
    [Data type]
    2–word
    [Unit of data]
    One ms
    [Valid data range]
    0 to 60000
    6758 Operation time (integrated value of one automatic operation time)
    [Data type]
    2–word
    [Unit of data]
    One minute
    [Valid data range]
    0 to 99999999
    This parameter displays the one automatic operation drive time (neitherstop nor hold state included). The operation time is automatically presetto 0 during the power–on sequence and the cycle start from the reset state.
    Hope this will help you some :cheers:
    Aug 2011
    2517
    I doubt any of those will help. even if they are all 0 it just means the part count will not count up but will just stay on 0. the problem is more likely it is not enabled in the option parameters. the clock and part count is an option......
    Apr 2011
    50
    It is an 18T controller and I have checked most of the parameters listed and i can find values in certain parameters that will tell me some of the info i am looking for but the problem has to be like " fordave11 " says... There must be a parameter or something just to turn these options ON?? Thanks for the replys so far!!!
    Jul 2010
    369
    Ahh Yes! Options parameters begin at 9900.
    Short on time right now but I can post some more info later.
    Good Luck!:cheers:
    Jan 2012
    16
    ok
    Aug 2011
    2517
    I sent you a PM with the info. it can not be posted here publicly. check your PMs.
    Apr 2011
    50
    Think were getting close....
    We can't get the control to accept the change on this bit (@&$#.#). We are setting PWE to 1 in MDI. Program project is off. Is there someting else we must do?
    Apr 2011
    50
    TO: fordav11 - Passwords?
    Aug 2011
    2517
    as I already said that can't be posted here. check your PMs
    Quote Originally Posted by fordav11 View Post
    Hi Fordav11,
    My parameter begin 9900 lost too. Can help to send to me? [email protected]
    Very much appreciated.
    Jan 2006
    61
    Re: Parameter problems- part count not working
    Go into ladder and search for the bit F62.7, it should eventually show you the line of logic for part count display and run time.
    Aug 2011
    34
    Check your PM, I sent you some info
    Mike
    Apr 2011
    50
    Re: Fanuc 18T Param.
    I'm not sure what we ended up doing but this machine has been gone for a few years now. Thanks for the input.
    Jan 2012
    so what was the solution please?
    i have a 21-m on a kira not showing count or cycle time....
    Jan 2014
    106
    Jreng1982,
    What is the model of the Kira machine you have?
    Jan 2012
    vtc 30 elite, funny thing is in the shop we have 6 of them.
    Two of them with 20-m controller cycle works but the 21-m panels don't lol.
    i'm sure its just a enable bit that needs to be turn from 0 to 1 but which one.
Page 1 of 2 12
  1. Replies: 1
    Last Post: 06-21-2012, 07:09 AM
  2. Part Count
    By Jerseycnc in forum Parametric Programing
    Last Post: 03-09-2012, 04:33 PM
  3. Part Count in Fanuc 21 MB
    By M.RISHIKESH in forum Fanuc
    Last Post: 10-22-2011, 01:29 PM
  4. What is important part count or utilization
    By chrisryn in forum MetalWork Discussion
    Last Post: 07-15-2009, 09:06 AM
