603,940 active members*
2,202 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Postform.M Modification for Fadal
Results 1 to 10 of 10
    May 2010
    I want to add a G73 to my Postform for a fadal. This is how I edited it:
    WorkDefault 1 # Work offset register default
    Drill # Drilling canned/manual cycle
    G81 R[Vclear] z[D] F[FRate] X[H] Y[V]
    end cancel
    Chip Break # Chip Break canned/manual cycle
    G73 X[H] Y[V] Z[D] Q[VBite] P[DWELL] R[Vclear] F[FRate]
    end cancel
    Peck # Pecking canned/manual cycle
    G83 R[Vclear] z[D] F[FRate] Q[VBite] X[H] Y[V]
    end cancel
    LTap # Left handed tapping cycle
    G74 R[Vclear] z[D] F[Frate] Q[VBite] X[H] Y[V]
    end cancel
    Tap # Tapping canned/manual cycle
    S[Speed] M5
    G84.2
    G84.1 R[Vclear] z[D] F[Frate] X[H] Y[V] S[Speed] M3
    end cancel
    Ream # Reaming canned/manual cycle
    G85 R[Vclear] z[D] F[FRate] X[H] Y[V]
    end cancel
    Bore # Boring canned/manual cycle
    G86 R[Vclear] z[D] F[FRate] X[H] Y[V]
    end cancel
    Back # Back boring canned/manual cycle
    G76 R[Vclear] z[D] F[FRate] Q[Sclear] X[H] Y[V]
    end cancel
    I attached a screen shot of the error I get when I run it.
    thanks for any info.
    May 2010
    Anyone?
    Oct 2009
    13
    Chip Break
    Tmcallister,
    There is not an option under NC->2 Axis->Drill called Chip Break. You can probably call it Custom1, Custom2, or Custom3, if any of them are listed on the drop down menu.
    Good luck,
    nick.
    PS It is odd that a high speed peck option has never been part of the menu.
    May 2010
    Yeah I know about the Chip break. It posts it out line by line, all in Z moves.
    I thought if I added the G73 cycle into my post and named it Chip Break that it would use the proper code. I must have done something wrong as it just throws an error when I go to post now. I was wondering if anyone new the right way to rdit the post so that this will work. I also tried calling it the custom 1. I got the same error.
    Thanks.
    Dec 2010
    23
    Hello,
    This is what you need to put into your post and be sure you click on the custom1 when you do the drill cycle, let me know.
    Custom1 # Chip Break canned/manual cycle
    end cancel
    May 2010
    That worked. Thank you very much. I was beating my head against the wall. The only thing I see different is the dwell so maybe that was it.
    Dec 2009
    80
    Hello,
    in your post I think you cannot write "Chip Break" in two words in the cycle sequence. Try Chipbreak instead, it should work.
    May 2012
    100
    Back Bore is only named "Back" in Postform as an example, so try "Break" for G73
    May 2003
    70
    To use the "Chip Break" option from surfcam use the following in Mpost template.
    ChipBreak
    G73 X[H] Y[V] Z[D] R[RLevel] F[FRate] Q[Step]
    end
    May 2003
    70
    FWIW the Chip Break option is present on newer versions of Surfcam, as I recall it wasn't there in Older Versions. If using the older versions you would be limited to using the Custom options as the other poster suggested.
  1. Can't remove post line #'s using postform.m
    By MrBoss8 in forum Surfcam
    Last Post: 04-11-2025, 05:58 AM
  2. Postform.m in Surfcam Vel 4.0
    By Jerseycnc in forum Surfcam
    Last Post: 09-27-2012, 07:50 PM
  3. need help with modification
    By ironofeden in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-23-2011, 06:21 PM
  4. Postform.m
    By moldcore in forum Surfcam
    Last Post: 04-05-2006, 02:16 PM
  5. New MCG's need modification
    By Swede in forum Servo Motors / Drives
    Last Post: 01-12-2005, 03:46 PM
