603,359 active members*
4,842 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Mixing servos and steppers?
Hybrid View
    Oct 2005
    78
    Has anyone here used both DC servos and steppers on a project? I'm considering using a large servo motor on my X axis, so that I can run my heavier screw, and steppers on my Y and Z. I'm concerned there may be discontinuities when doing circular interpolation, whichi will be doing often.
    35494
    You shouldn't have any problems mixing steppers and servos. But, if you're servo axis is much faster than your stepper axis, you'll be limited to the speed of the slowest axis when doing moves using both, such as circular moves. That would probably be the only issue.
    Aug 2004
    2849
    So, the best bet is to use the z-axis as your stepper axis...the other two should be servos.
