586,108 active members*
3,143 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Text engraving on cylinder side
    May 2012
    Trying to engrave text on side of a 1.5 inch cylinder. Did a V no problem use Z, C, and M15 M16. Now need to do a P and I don't know how to do the radius. Should I be using the same method or is there an easy way to do this? The letters are only .25 high and .125 wide. I'm on an Okuma b300. OSP-P200L
    Aug 2011
    2517
    it would be easier to use the Y axis as well. i.e. like a mill but YZ and X for depth.
    a few posts below this someone has already provided a similar solution using User Task
    http://www.cnczone.com/forums/okuma/...live_tool.html
  1. Wrapping Text Around a Cylinder
    By aus10eww in forum BobCad-Cam
    Last Post: 04-12-2012, 08:41 PM
  2. Engraving Around a Cylinder Using 2D Contouring
    By dkaustin in forum SprutCAM
    Last Post: 06-04-2011, 07:39 PM
  3. Engraving on a cylinder
    By compunerdy in forum SprutCAM
    Last Post: 06-23-2010, 04:32 AM
  4. Engraving around a cylinder
    By musall37 in forum Haas Mills
    Last Post: 03-09-2010, 06:40 AM
  5. Cylinder threaded in the side?
    By LeeWay in forum Community Club House
    Last Post: 06-13-2009, 02:35 PM
