588,515 active members*
4,715 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Z axis height as a function of Y-axis position..
    Dec 2011
    10
    Does anybody have an opinion or experience of the variation of the Z-height as a function of the position of the Y-axis?
    Below is a graph. The Z-axis height is measured relative a reference surface plate (with an accuracy of 2.8 microns). As can be seen from the graph we have an almost sinus shaped variation of the Z-axis height. The period of the “sinus” curve matches the pitch of the Y-axis leads screw. The variation is about 5 microns at max. Is this (sinus shape) normal?!
    The CNC router is a type with a gantry. See photo below. For the sake of clarity, my primary use is for PCB etching.
    Regards
    Bo
    Mar 2008
    267
    Typically recirculating ball nut screws have a cyclic nature usually associated with positional error along the length of the screw.
    The cross axis coupling You are experiencing may be due to a small degree of eccentricity ( rolled screw versus ground screw?) and too compliant a machine frame? bearing system where the screw is affecting stresses in the axis and causing the tool tip to oscillate.
  1. Has anyone used the 5th axis function
    By Don C in forum Uncategorised CAM Discussion
    Last Post: 10-04-2012, 10:08 PM
  2. Z axis height not consistant
    By Absolute Steve in forum WinCnc
    Last Post: 11-03-2010, 05:01 PM
  3. function of the Z axis
    By jochesfor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-11-2008, 08:06 PM
  4. TPI for Torch height axis
    By edwardpic in forum Waterjet General Topics
    Last Post: 08-30-2006, 02:29 PM
  5. Z-Axis Height?
    By barkster in forum DIY CNC Router Table Machines
    Last Post: 03-22-2004, 11:54 PM
