586,761 active members*
7,738 visitors online*
Results 1 to 10 of 10
    Apr 2012
    35
    Does anyone try cutting leather...
    I did try to cut leather and i did it but the piece was burned out and deformed and I used speed 14 and power 28. And I have 80w power CO2 laser with laser cut 5.3 software.
    I've also try to engrave with speed 400 and power 27 and was good but still no perfect.
    So is there a problem or is there some better settings.
    If anyone have idea please do wrote.
    Goran
    Apr 2006
    251
    Do you have high pressure air assist? That would help. I don't really like cutting leather but engraving it is OK. IIRC high power and speed is the way to go with leather.
    Apr 2012
    35
    What does IIRC means. And I have high presure air assist.
    Engraving is not so bad but cutting is.
    Aug 2008
    247
    IIRC == If I Recall Correctly
    Sep 2011
    296
    Your engraving speed is much faster than cutting speed, that's the reason why Engraving is not so bad but cutting is. You can try a little faster speed when cutting.
    And as for high pressure air assist, there are many kinds, for example, 500W, 750W,1500W,2500W... Which one do you have?
    Of cause the result with the help of larger ones are much better than small ones when working on Inflammable materials as paper, wood, leather, cloth.
    So if you do leather cutting offten, you can consider changing to a larger one.
    Melody
    [email protected]
    Feb 2012
    387
    engraving
    Hi
    If engraving ,we usally use a newspaper on the top of leather and make it a little water,then will help much. you can try it :wee: and the speed and power also is very important
    Any others,feel free to ask me
    Best Regards
    Lucy Lee
    G.WEIKE LASER
    [email protected]
    Quote Originally Posted by jassk View Post
    Goran
    Red face
    hi,
    I also learned. It is cute.
    Abby
    Quote Originally Posted by johnohara View Post
    Apr 2012
    35
    and what about speed and power. what do you suggest ?
    I've tryed 325 speed with 27 power and 400 speed with 31 power , so any other suggestions about engraving.
    thanks
    Sep 2011
    296
    HI, jassk,
    I have asked advice from our technican. He said no big relationship with the power and speed setting. The leather is really easy burnt. It is maybe the material problem. He suggested you to find a bigger power air compressor as i told you before. And he suggested you to use Co2 or N2 instead of common air to avoid burning.
    Melody
    [email protected]
    Apr 2006
    251
    Melody is right, leather isn't really a good candidate for laser cutting. It chars and stinks!
  1. Drag knife for leather cutting?
    By jasonw22@gmail. in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 02-28-2012, 04:21 PM
  2. Leather Laser engraving cutting question
    By echojdlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-11-2012, 11:37 AM
  3. Cutting & engraving leather
    By Dubliner in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-26-2010, 08:40 AM
  4. help and advice needed - laser cutting leather
    By geekinesis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-03-2010, 09:56 AM
  5. Cutting Leather?!?!
    By analogman in forum DIY CNC Router Table Machines
    Last Post: 10-14-2009, 07:07 PM
