586,065 active members*
4,876 visitors online*
Results 1 to 10 of 10
    Apr 2004
    8
    My first router/mill
    Hello!
    I am building my first cnc-router/mill. Started this project one year ago…I will use it for rapid prototyping. All I have left is to build the frame (have bought all other parts). I will really value your thoughts and opinions before I start to build the frame (see attachments). The frame will be made of steel. I have started to make a “dummy”-frame in wood for testing.
    Specs:
    Table size, 600x500 (including 11 position ATC)
    Travel, 530x530x300 (X,Y,Z)
    Maximum feed, 1000mm/s (X,Y), 500mm/s (Z)
    Controller, Fawoo FWMC-U200, four axes
    Servo motors, Mitsubishi HC-KFS43, 400W
    Servo amplifier, Mitsubishi MR-J2S-40A, 400W
    Linear rails, THK SHS20 820mm and 1000mm, SHS20LV blocks
    Ball screws, NSK 20x20x540mm
    Support for ball screws, THK BF15 and BK15
    Coupling, Multi-beam
    Spindle, Kavo 4041, 500W, 5000-50000rpm
    Hf Converter, Kavo 4442
    Z-axis, Parker 406XR
    Countering force, Festo DGP-25-PPV-A-B
    Table, Witte alufix
    Jakob
    Apr 2003
    1873
    Jakob,
    You are using quality parts, the design looks fairley typical but well thought out, should make for a very nice piece of equipment.
    I like this idea, gives you a chance to make changes to the final fabrication as improvements are discovered in the dummy build up. Not many seem to do this but I think it is a smart move.
    Ken
    Apr 2004
    8
    Thank you for your comments Ken!
    Jakob
    Nov 2004
    389
    Yes,
    A nice set of CAD illustations. Looks very well thought out.
    Also a nice list of components, should be the business.
    Can you please expand on the table details. Witte alufix ?
    Cheers
    Apr 2004
    8
    Hello Santiniuk,
    “Witte Alufix is a modular fixturing system made out of high-tensile aluminium for measuring fixtures, checking gauges, assembly or welding fixtures, cubings, gages ....
    It is also used for setting up prototypes, stereolithography and design development.”
    http://www.horst-witte.de
    I bought it used and thought it would be nice for setting up work pieces in the router!
    Jakob
    May 2005
    925
    It uses the same concept I used for mine (http://www.cnczone.com/forums/showthread.php?t=10927) take a look, if you find something that may help you, please let me know and I'll take photos
    Pablo
    Apr 2004
    8
    Quote Originally Posted by peu
    Pablo
    Hi Pablo,
    Nice work! I will take a look!
    Jakob
    Apr 2004
    8
    I wasn’t 100 percent satisfied with my first design so I started from the beginning again! Do you like the new design? Does it have any disadvantages? From the beginning I had imagine to have the fourth axis on the table but now it is on the Z-axis. Please feel free to comment.
    Jakob
    Attached Thumbnails Attached Thumbnails nkcnc1.jpg   nkcnc2.jpg   nkcnc3.jpg   nkcnc4.jpg
    Apr 2004
    8
    Hello,
    some more pictures!
    Jakob
    Jan 2011
    Re: My first router/mill
    Hi friends I am writing in Turkey. I bought an old cnc router. It has a fwmc-u200 control unit. I couldn't find the program anywhere. I'm in trouble. My computer is not working because it is not a program. I can find this program. Jakob can you help
  1. Router vs. mill
    By Ugilten in forum DIY CNC Router Table Machines
    Last Post: 08-10-2016, 12:01 PM
  2. CNC Router/Mill
    By TheHitman04 in forum Open Source CNC Machine Designs
    Last Post: 10-04-2012, 11:52 PM
  3. CNC Mill or CNC Router?
    By spacifique1 in forum Australia, New Zealand Club House
    Last Post: 03-16-2007, 05:59 AM
  4. 4x4 cnc mill router
    By jarr88 in forum Open Source CNC Machine Designs
    Last Post: 06-12-2006, 05:24 AM
