603,929 active members*
2,715 visitors online*
Results 1 to 6 of 6
    Sep 2011
    11
    thread milling
    hello, was trying out thread milling, is it possible to do it with manually written program?
    Jul 2005
    12177
    Sure, I do it all the time. Here is the code to cut a 16tpi internal thread 1.500" major diameter about 0.650" long.
    N5000 T5 M06 (THREAD MILL 16TPI)
    N5001 G43 H05
    N5002 M03 S8000
    N5003 G00 X0. Y0. Z1.
    N5004 Z-0.59 M08
    N5005 G41 D05 G00 Y-0.4
    N5006 G03 I0. J0.575 Y0.75 F30.
    N5007 G91 G03 I0. J-0.75 Z0.0625 F30. L3
    N5008 G90 G03 I0. J-0.575 Y-0.4
    N5009 G40 G00 X0. Y0. Z1.
    N5010 M99
    Sep 2011
    11
    Quote Originally Posted by Geof View Post
    N5001 G43 H05
    N5002 M03 S8000
    N5004 Z-0.59 M08
    N5010 M99
    thanks! is the L3 meant for subprogram just for each pitch increment for Z ? or L3 works itself for 3 repetition with g91 in the line of code?
    Jul 2005
    12177
    This was written for a Haas mill which can have an L count in a G03 command.
    This is an internal right hand thread so the thread mill has to 'screw' itself out.
    N5004 drops the mill to the thread depth.
    N5005 sets tool comp with a small Y negative move.
    N5006 enters the cut tangentially through a 180 degree arc.
    N5007 does three counterclockwise circles incrementing up 0.0625 per circle. Not all machines can do this so this may have to be written as three absolut moves on some machines.
    N5008 exits tangentially.
    N5009 cancels tool comp.
    Sep 2011
    11
    i see.,, thanks
    May 2012
    100
    Just add Z depth to a 360 deg interpolation block.
    And by making it a sub program, you can repeat it
    as many times as you want, until final depth.
  1. thread milling
    By tjd10684 in forum Rhinocam
    Last Post: 05-18-2011, 06:10 PM
  2. Thread milling
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-30-2010, 11:23 AM
  3. new to thread milling
    By TOM R in forum G-Code Programing
    Last Post: 09-12-2010, 03:46 PM
  4. Thread milling on X2
    By webgeek in forum Benchtop Machines
    Last Post: 04-02-2010, 02:13 AM
  5. thread milling help
    By BAD DOG in forum Daewoo/Doosan
    Last Post: 11-28-2008, 07:20 AM
