603,795 active members*
2,941 visitors online*
    Sep 2004
    23
    Standards for bolt & c'bore clearance holes
    I'm working on designing a few small projects.
    I was wondering if anyone could recommend a software which lists all clearance holes and c'bores, c'sinks sizes for bolts/screws.
    I know high end design softwares (Solidworks, Inventor) have this built in but I am not using any of these...
    I measure the bolt/screw and make my hole a bit bigger, etc...
    This is only to be used for a few small projects so expensive solutions are unfortunately not an option...
    Thanks !
    May 2004
    4519
    All the information is available via google, why do you need software its basically reference material? Just keep a pdf file handy...
    for example
    Counterbored Holes Dimensions (inch)
    Sep 2005
    Save yourself some money and pick up a used copy (or last year's edition on remainder) of Machinery's on eBay or Amazon. The content changes slowly from edition to edition and certainly the dimensions of standard fasteners (and thus the holes they go in) have been unchanged for decades.
    Mar 2006
    2712
    The bolt/screw manufacturers have "slide charts" with your needed info on them. Mine are from Holo-Krome. Since I'm in the USofA, I use both English and Metric.LOL
    Dick Z
    DZASTR
  1. Drilling 2mm holes through 19mm bolt heads in 316L
    By SQT18MS in forum MetalWork Discussion
    Last Post: 01-25-2016, 07:40 PM
  2. Novakon UR or CSA Standards
    By TimM2 in forum Novakon
    Last Post: 09-09-2011, 05:00 AM
  3. Cover Bolt Holes on 3D surface
    By dingo0722 in forum BobCad-Cam
    Last Post: 06-16-2011, 03:34 AM
  4. Milling rectangular holes on a bolt circle
    By 69ss396 in forum Haas Mills
    Last Post: 04-16-2010, 10:54 PM
  5. NEMA standards
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 08-17-2004, 01:32 PM
